direct log tranfer when wifi not available
nismoautoxr
Post by nismoautoxr »
I spent the weekend at the track and i had no wifi available . I did however have the capability to connect to my android via bluetooth with my PC. I attempted to transfer my logs from shadowdash to my PC over bluetooth and did but could not open them with megalogviewer on the PC. What should I have done to make this possible when I had no way to send to shadowtuner first?
Ricky-
1995 Nissan 240sx, 403 LS strokerv8 N/A 6speed trans
MS3&MS3X v.3.0 PCB
42lb/hr Hi-Z inj.,230/232 @.050 on 114LSA cam
sequential fuel and sequential spark
LS3/LSA card MAF sensor
97 Mazda MX5
MS3 2002 vvt motor
.60 trim T4 Turbo at 15 PSI
Re: direct log tranfer when wifi not available
Post by LT401Vette »
That should work fine.
Any Idea what was in the files when the got to your PC? Were they empty files possible?
You can also plug into USB and browse the tablets files system.
nismoautoxr
well the problem that occurred is unclear. The first time I tried it they showed up in my bluetooth folder as .ATF files and could not be opened but I think that the file transfer was incomplete at the time I tried to open it . I just tried is again with the same logs via bluetooth between the pc and the phone and it worked just fine and showed up as an MSL with nothing after it .I did not have my usb cable at the track which was the reason i was doing it over bluetooth but it worked this time so . That was the first time I have tried to do it that way so it appears I did not allow enough time for the transfer to completely happen .
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
