I recently updated my MS firmware to MS3 pre-1.3.1 beta 2. Since then I haven't been able to get Shadow Dash to work properly. First I was having problems connecting over blue tooth. I replaced the SD mainController.ini file with the .ini that came with the firmware. After that I could connect but some of my custom gauges don't work (EGO% correct for example). I'm not sure if updating the mainController.ini helped or if being able to connect after the update was just a happy coincidence.
Will there be updated version of SD that will work with S3 pre-1.3.1 beta 2? If not do I need to do something else to get SD to work, update mainController.ini with a modified version? Be patient and wait for a release version of the firmware and SD?
Problems getting Shadow Dash to work with MS3 pre-1.3.1 beta
Re: Problems getting Shadow Dash to work with MS3 pre-1.3.1
The beta is out to play nice with it.
