Shadow Dash Connection issue
Hello,
i use Shadow Dash on my Phone and my Tablet.
On the Phone every Thing works as expected.
But on the Tablet it isn't connected correctly.
The Connection is established. But just before i see the Runtime Data the Connection is cancelled.
I have appended my appDebug.txt. Best regards
Alfa 156 GTA
Alfa 75 Race Car MS III -- alway latest FW
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Test MS II --always latest FW
Tunerstudio V2.6.11 Registered
MegaLog Viewer V3.4.04 Registered
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Re: Shadow Dash Connection issue
No investigation so far?
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
I was traveling the past couple weeks.
What kind of tablet is it?
I see in the log it is indeed connecting and getting data, but then loosing connection.
Ah okay.LT401Vette wrote:I was traveling the past couple weeks.
It's and Odys Space.LT401Vette wrote:What kind of tablet is it?
Android Version is in the Debug.txt i think.
Yes Correct. That is the behavior.LT401Vette wrote:I see in the log it is indeed connecting and getting data, but then loosing connection.
I had already a connection with the MS with this Bluetooth Adapter and that Tablet with an older Version of Shadow Dash.
But now it won't connect.
I can't figure out why the connection is lost just before the Data are Displayed.
Another cool thing would be that Shadow Dash only Turn Bluetooth off on exit
when it was off during the Shadow Dash Startup.
Best Regards
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Yesterday i have tried it again with Version 1.25 but it's the same behavior.
With my HTC Phone and Android 2.3.5 it works as expected.
With the Odys Tablet and Android 2.3 it doesn't work.
Runtime Data Size and the Software Version will be Displayed.
The Bar goes from left to right and stops a little bit before the End.
Then it says again "Connected...." the Bar hangs at the same Position.
I don't know what i can do.
I've tried a Factory Reset but it doesn't help.
A while ago it works with the Odys and Shadow Dash.
Best Regards
Best Regards
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
What firmware are you on?
I noticed in the above appDebug.txt which is a bit old now that you were on 3.3.2 beta5 and that ini was not on the server. I just put it up, but if you are on a newer firmware I can check to make sure that one is on the server.
Actually i have 3.3.2. beta 5.
Best Regards
Best Regards
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Did you try it again now that the ini is up there/
Make sure your tablet has internet connection the 1st time you connect to it.
I've tried it again with Internet Connection.
Now the Tablet is connected to the Megasquirt.
I've seen a Message on the Tablet "Downloading the Config..."
Should we always have intenet Connection when we trie to Connect to a new Frimware?
Best Regards
Best Regards
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Typically yes if it is an alpha or beta firmware that was recently released especially. For each new SD release I bundle all the mainstream ini files, but otherwise it will need to download the ini that 1st time.Should we always have intenet Connection when we trie to Connect to a new Frimware?
