So I started messing with Shadowdash. Since it doesn't have any actual tuning options in it, I'm bouncing between that and msdroid.
I noticed the "upload" option in shadowdash and figured this would be easier than using an SMB share and transferring the file to my pc (only when I'm at home). I could do it on the go!
Once I get done logging some stuff and head back home, I get on the desktop and poke around efianalytics site. I can't find any access to the logs.
How do I go about obtaining these files?
Also, on a side note, how do I map the GPS data?
ShadowDash Logs. in the cloud?
Re: ShadowDash Logs. in the cloud?
Ok, so go to http://www.shadowtuner.com and log in. (Like an arse, I assumed it would just go to efianalytics website)
Now, one thought Phil; Since ts and mlv are java based, couldn't those run in the browser, or open my file instantly somehow?
I'm not sure what running MLV from the browser would do, compared to just downloading the file and letting MLV open it as the associated app. it would take permissions to get out of the sound box too. However it has been on the todo list for a while to have MLV log into Shadowtuner.com and list the files from there to download and open them directly from the web instead of needing a web browser.
Sometimes I want to look over my logs at work. I could install MLV, that isn't a problem, I just don't always use the same computer.LT401Vette wrote:I'm not sure what running MLV from the browser would do, compared to just downloading the file and letting MLV open it as the associated app. it would take permissions to get out of the sound box too. However it has been on the todo list for a while to have MLV log into Shadowtuner.com and list the files from there to download and open them directly from the web instead of needing a web browser.
But having MLV be able to log into shadowtuner would be nice, then you could easily put your tune file up as well. Also, shadowdash should be able to upload the currenttune file.
It would be nice to give others access to the files for diagnostic purposes, maybe with a password or something by a registered user, and keep a log.
Maybe allow uploading a whole "Project File", I do have a few megasquirted vehicles.
That is very much the original intent, but I haven't done much with shadowtuner.com for quite a spell as other efforts keep getting priority. It is good to hear that you do have interest in these.It would be nice to give others access to the files for diagnostic purposes, maybe with a password or something by a registered user, and keep a log.
