shadow dash cant find controller firmware 3.30
Re: shadow dash cant find controller firmware 3.30
I fear so... But I would expect an Acer tablet to work fine. Shadow Logger logic is pretty basic.
Can you have shadow logger capture a Comm Debug file and send it? I'm curious what if any data is making it back.
Ok will do it this week.What tablet is working perfect with no problems?LT401Vette wrote:I fear so... But I would expect an Acer tablet to work fine. Shadow Logger logic is pretty basic.
Can you have shadow logger captured a Comm Debug file and send it? I'm curious what if any data is making it back.
Frank Racing,Naranjito Puerto Rico,installations and tuning solutions
FrankRacing.Naranjito@gmail.com
There are a lot of them. So far I have seen few device specific troubles beyond a couple with BT problems in particular images. Typically those BT Trouble cause a problem connecting, but reading. Where here it seems you are connecting fine, but can't communicate through it. Data is sent, but no response. That usually points to a problem with the BT Adapters configuration. However, as you can communicate with your phone, the BT Adapter must be working..... So I would still like to figure out what is going on here.
In my testing I use:
- Acer A510
- Google Nexus 7 (2012)
- HTC One
- An old LG with 2.3 Android
- Acer A510
- HTC One
I think the tablet is ok and the problem is the Bluetooth adapter,now msdroid stops communicating after a few minutes.I will buy another adapter from you and test.LT401Vette wrote:There are a lot of them. So far I have seen few device specific troubles beyond a couple with BT problems in particular images. Typically those BT Trouble cause a problem connecting, but reading. Where here it seems you are connecting fine, but can't communicate through it. Data is sent, but no response. That usually points to a problem with the BT Adapters configuration. However, as you can communicate with your phone, the BT Adapter must be working..... So I would still like to figure out what is going on here.
- Acer A510
- HTC One
Hi,I installed a new Bluetooth adapter and still the same,use the new 1.25 v and still the same
Code: Select all
Shadow Dash MS 1.25 Started.
Start time: Wed Jun 25 12:45:37 EDT 2014
Android Version: 4.2.2
INFO 0.02000(s):
DEBUG 0.02400(s): Starting ShadowDash Service
6/25/14 12:45:37 PM :Debug: Command Non-VolatileBytes for F resolved to: x46 F
6/25/14 12:45:37 PM :Debug: Command Non-VolatileBytes for I resolved to: x49 I
6/25/14 12:45:37 PM :Debug: Command Non-VolatileBytes for f resolved to: x66 f
DEBUG 22.35800(s): Installation Source: com.android.vending, com.efiAnalytics.shadowdash
DEBUG 22.38200(s): Installation source: com.android.vending
INFO 22.38200(s): Licensing managed by google
INFO 22.45800(s): License Validated by Google
DEBUG 22.45900(s): Cached EFI Activation of Google license validated.
DEBUG 22.46000(s): ShadowDashActivity::onCreate called
6/25/14 12:46:00 PM :Debug: Get LocationProvider
6/25/14 12:46:00 PM :Debug: locationProvider: gps
6/25/14 12:46:00 PM :Debug: bestProviderName: gps
6/25/14 12:46:00 PM :Info: GPSManager initialized
DEBUG 22.51700(s): ShadowDashActivity: viewSwitcher created
DEBUG 22.56800(s): ShadowDashActivity:: setContent
DEBUG 22.56800(s): ShadowDashActivity:: added home
DEBUG 22.56900(s): ShadowDashActivity:: got references
DEBUG 22.62000(s): ShadowDashActivity:: created home dash
DEBUG 22.62100(s): ShadowDashActivity:: set Home dash
DEBUG 22.62200(s): ShadowDashActivity: created buttons
DEBUG 22.62300(s): ShadowDashActivity: readPrefs ??
DEBUG 22.62300(s): ShadowDashActivity: checkBtInitialization
DEBUG 22.62300(s): ShadowDashActivity: updateDeviceInfoDisplay()
DEBUG 22.62300(s): ShadowDashActivity: queued logs for upload
DEBUG 22.62400(s): ShadowDashActivity: gesture stuff
DEBUG 22.62400(s): ShadowDashActivity: set touch listeners
DEBUG 22.62500(s): ShadowDashActivity: checkExpiration()
DEBUG 22.62800(s): ShadowDashActivity: initDashboards()
DEBUG 22.63100(s): ShadowDashActivity: addSavedDashboards()
DEBUG 22.63400(s): ShadowDashActivity: onCreate() DONE
DEBUG 22.63600(s): LoggerMonitor::onStart() called
DEBUG 22.63700(s): ShadowDashActivity: initializeWakeLock()
DEBUG 22.63800(s): LoggerMonitor::onResume() called
INFO 22.66600(s): Initializing GPS Manager
6/25/14 12:46:00 PM :Info: Initializing internal GPS
6/25/14 12:46:00 PM :Info: Internal GPS initialized
6/25/14 12:46:00 PM :Debug: ExtGPSManager.stop() ExternalGPS
INFO 22.88300(s): Time to read cached version of home_landscape.dash: 246.0
INFO 23.10200(s): Time to read cached version of home_portrait.dash: 218.0
6/25/14 12:46:00 PM :Debug: Typeface for 'Arial Normal' not found.
DEBUG 23.21300(s): ShadowDashActivity: addSavedDashboards() complete: 582
INFO 23.44700(s): Found FTDI Device 0
INFO 23.45100(s): No Prolific devices found.
INFO 23.45400(s): Creating Bluetooth Interface to connect to: EFI Analytics 05: 00:12:6F:23:23:12
INFO 25.63200(s): Calling Connect
INFO 25.63500(s): Connecting Attempt started
6/25/14 12:46:03 PM :Debug: Got BT Socket
6/25/14 12:46:03 PM :Debug: About to connect Socket
INFO 31.65000(s): Connection Attempt failed
INFO 33.65400(s): Calling Connect
INFO 33.65700(s): Connecting Attempt started
6/25/14 12:46:11 PM :Debug: Got BT Socket
6/25/14 12:46:11 PM :Debug: About to connect Socket
INFO 33.68800(s): Connection Attempt failed
INFO 35.68900(s): Calling Connect
INFO 35.69800(s): Connecting Attempt started
6/25/14 12:46:13 PM :Debug: Got BT Socket
6/25/14 12:46:13 PM :Debug: About to connect Socket
INFO 35.73200(s): Connection Attempt failed
INFO 37.74200(s): Calling Connect
INFO 37.74500(s): Connecting Attempt started
6/25/14 12:46:15 PM :Debug: Got BT Socket
6/25/14 12:46:15 PM :Debug: About to connect Socket
INFO 37.79300(s): Connection Attempt failed
INFO 39.79400(s): Calling Connect
INFO 39.79600(s): Connecting Attempt started
6/25/14 12:46:17 PM :Debug: Got BT Socket
6/25/14 12:46:17 PM :Debug: About to connect Socket
INFO 39.81800(s): Connection Attempt failed
INFO 41.82200(s): Calling Connect
INFO 41.82400(s): Connecting Attempt started
6/25/14 12:46:19 PM :Debug: Got BT Socket
6/25/14 12:46:19 PM :Debug: About to connect Socket
INFO 41.83600(s): Connection Attempt failed
INFO 43.83800(s): Calling Connect
INFO 43.85300(s): Connecting Attempt started
6/25/14 12:46:21 PM :Debug: Got BT Socket
6/25/14 12:46:21 PM :Debug: About to connect Socket
INFO 43.88300(s): Connection Attempt failed
INFO 45.89200(s): Calling Connect
INFO 45.90100(s): Connecting Attempt started
6/25/14 12:46:23 PM :Debug: Got BT Socket
6/25/14 12:46:23 PM :Debug: About to connect Socket
INFO 47.83800(s): Connection Attempt failed
INFO 49.84100(s): Calling Connect
INFO 49.84700(s): Connecting Attempt started
6/25/14 12:46:27 PM :Debug: Got BT Socket
6/25/14 12:46:27 PM :Debug: About to connect Socket
INFO 49.86900(s): Connection Attempt failed
DEBUG 51.67100(s): LoggerMonitor::onPause() called
INFO 51.75000(s): Found FTDI Device 0
INFO 51.75300(s): No Prolific devices found.
INFO 51.87000(s): Calling Connect
INFO 51.87200(s): Connecting Attempt started
6/25/14 12:46:29 PM :Debug: Got BT Socket
6/25/14 12:46:29 PM :Debug: About to connect Socket
INFO 51.88800(s): Connection Attempt failed
INFO 53.89100(s): Calling Connect
INFO 53.89300(s): Connecting Attempt started
6/25/14 12:46:31 PM :Debug: Got BT Socket
6/25/14 12:46:31 PM :Debug: About to connect Socket
INFO 53.91400(s): Connection Attempt failed
INFO 55.91600(s): Calling Connect
INFO 55.92000(s): Connecting Attempt started
6/25/14 12:46:33 PM :Debug: Got BT Socket
6/25/14 12:46:33 PM :Debug: About to connect Socket
INFO 55.95800(s): Connection Attempt failed
INFO 57.95900(s): Calling Connect
INFO 57.96300(s): Connecting Attempt started
6/25/14 12:46:35 PM :Debug: Got BT Socket
6/25/14 12:46:35 PM :Debug: About to connect Socket
INFO 58.00200(s): Connection Attempt failed
INFO 60.00300(s): Calling Connect
INFO 60.00500(s): Connecting Attempt started
6/25/14 12:46:37 PM :Debug: Got BT Socket
6/25/14 12:46:37 PM :Debug: About to connect Socket
INFO 60.02300(s): Connection Attempt failed
Start time: Wed Jun 25 12:46:38 EDT 2014
INFO 0.00100(s):
DEBUG 0.01100(s): Starting ShadowDash Service
6/25/14 12:46:38 PM :Debug: Command Non-VolatileBytes for F resolved to: x46 F
6/25/14 12:46:38 PM :Debug: Command Non-VolatileBytes for I resolved to: x49 I
6/25/14 12:46:38 PM :Debug: Command Non-VolatileBytes for f resolved to: x66 f
DEBUG 0.04700(s): Installation Source: com.android.vending, com.efiAnalytics.shadowdash
DEBUG 0.05100(s): Installation source: com.android.vending
INFO 0.05200(s): Licensing managed by google
INFO 0.10900(s): License Validated by Google
DEBUG 0.11000(s): Cached EFI Activation of Google license validated.
DEBUG 0.11000(s): ShadowDashActivity::onCreate called
6/25/14 12:46:38 PM :Debug: Get LocationProvider
6/25/14 12:46:38 PM :Debug: locationProvider: gps
6/25/14 12:46:38 PM :Debug: bestProviderName: gps
6/25/14 12:46:38 PM :Info: GPSManager initialized
DEBUG 0.15700(s): ShadowDashActivity: viewSwitcher created
DEBUG 0.19400(s): ShadowDashActivity:: setContent
DEBUG 0.19400(s): ShadowDashActivity:: added home
DEBUG 0.19500(s): ShadowDashActivity:: got references
DEBUG 0.24800(s): ShadowDashActivity:: created home dash
DEBUG 0.24800(s): ShadowDashActivity:: set Home dash
DEBUG 0.24900(s): ShadowDashActivity: created buttons
DEBUG 0.25300(s): ShadowDashActivity: readPrefs ??
DEBUG 0.25400(s): ShadowDashActivity: checkBtInitialization
DEBUG 0.25400(s): ShadowDashActivity: updateDeviceInfoDisplay()
DEBUG 0.25500(s): ShadowDashActivity: queued logs for upload
DEBUG 0.25500(s): ShadowDashActivity: gesture stuff
DEBUG 0.25600(s): ShadowDashActivity: set touch listeners
DEBUG 0.25600(s): ShadowDashActivity: checkExpiration()
DEBUG 0.25900(s): ShadowDashActivity: initDashboards()
DEBUG 0.25900(s): ShadowDashActivity: addSavedDashboards()
DEBUG 0.26100(s): ShadowDashActivity: onCreate() DONE
DEBUG 0.26200(s): LoggerMonitor::onStart() called
DEBUG 0.26200(s): ShadowDashActivity: initializeWakeLock()
DEBUG 0.26500(s): LoggerMonitor::onResume() called
INFO 0.28800(s): Initializing GPS Manager
6/25/14 12:46:39 PM :Info: Initializing internal GPS
6/25/14 12:46:39 PM :Info: Internal GPS initialized
6/25/14 12:46:39 PM :Debug: ExtGPSManager.stop() ExternalGPS
INFO 0.43700(s): Time to read cached version of home_landscape.dash: 175.0
INFO 0.52300(s): Time to read cached version of home_portrait.dash: 84.0
DEBUG 0.60900(s): ShadowDashActivity: addSavedDashboards() complete: 350
6/25/14 12:46:39 PM :Debug: Typeface for 'Arial Normal' not found.
INFO 1.09000(s): Found FTDI Device 0
INFO 1.10200(s): No Prolific devices found.
INFO 1.10500(s): Creating Bluetooth Interface to connect to: EFI Analytics 05: 00:12:6F:23:23:12
INFO 3.26100(s): Calling Connect
INFO 3.26300(s): Connecting Attempt started
6/25/14 12:46:42 PM :Debug: Got BT Socket
6/25/14 12:46:42 PM :Debug: About to connect Socket
INFO 4.89300(s): Connection Attempt failed
INFO 6.89500(s): Calling Connect
INFO 6.89600(s): Connecting Attempt started
6/25/14 12:46:45 PM :Debug: Got BT Socket
6/25/14 12:46:45 PM :Debug: About to connect Socket
INFO 6.90800(s): Connection Attempt failed
INFO 8.90900(s): Calling Connect
INFO 8.91200(s): Connecting Attempt started
6/25/14 12:46:47 PM :Debug: Got BT Socket
6/25/14 12:46:47 PM :Debug: About to connect Socket
INFO 8.92500(s): Connection Attempt failed
INFO 10.87500(s): Stopped runtime reads
INFO 10.87700(s): Connection closing: EFI Analytics 05
DEBUG 10.88100(s): LoggerMonitor::onBackPressed() called, exiting app
################# Exit ####################
DEBUG 10.88400(s): LoggerMonitor::onPause() called
DEBUG 11.40000(s): LoggerMonitor::onStop() called
6/25/14 12:46:50 PM :Debug: ExtGPSManager.stop() ExternalGPS
DEBUG 53.49100(s): Installation Source: com.android.vending, com.efiAnalytics.shadowdash
DEBUG 53.49600(s): Installation source: com.android.vending
INFO 53.49600(s): Licensing managed by google
INFO 53.55300(s): License Validated by Google
DEBUG 53.55600(s): Cached EFI Activation of Google license validated.
DEBUG 53.55900(s): ShadowDashActivity::onCreate called
DEBUG 53.59900(s): ShadowDashActivity: viewSwitcher created
DEBUG 53.61800(s): ShadowDashActivity:: setContent
DEBUG 53.61800(s): ShadowDashActivity:: added home
DEBUG 53.61900(s): ShadowDashActivity:: got references
DEBUG 53.61900(s): ShadowDashActivity:: set Home dash
DEBUG 53.62000(s): ShadowDashActivity: created buttons
DEBUG 53.62000(s): ShadowDashActivity: readPrefs ??
DEBUG 53.62100(s): ShadowDashActivity: checkBtInitialization
DEBUG 53.62100(s): ShadowDashActivity: updateDeviceInfoDisplay()
DEBUG 53.62100(s): ShadowDashActivity: queued logs for upload
DEBUG 53.62100(s): ShadowDashActivity: gesture stuff
DEBUG 53.62200(s): ShadowDashActivity: set touch listeners
DEBUG 53.62500(s): ShadowDashActivity: checkExpiration()
DEBUG 53.62600(s): ShadowDashActivity: initDashboards()
INFO 53.62700(s): Calling Connect
DEBUG 53.62800(s): ShadowDashActivity: onCreate() DONE
DEBUG 53.63000(s): LoggerMonitor::onStart() called
DEBUG 53.63100(s): ShadowDashActivity: initializeWakeLock()
DEBUG 53.63100(s): LoggerMonitor::onResume() called
INFO 53.64300(s): Initializing GPS Manager
6/25/14 12:47:32 PM :Info: Initializing internal GPS
6/25/14 12:47:32 PM :Info: Internal GPS initialized
6/25/14 12:47:32 PM :Debug: ExtGPSManager.stop() ExternalGPS
6/25/14 12:47:32 PM :Debug: Typeface for 'Arial Normal' not found.
INFO 54.43400(s): Found FTDI Device 0
INFO 54.43600(s): No Prolific devices found.
INFO 55.63000(s): Calling Connect
INFO 57.63400(s): Calling Connect
INFO 59.63600(s): Calling Connect
INFO 60.44400(s): Selected Adapter needs to be Paired. Go into Android Bluetooth settings.
6/25/14 12:47:39 PM :Info: Toast: Selected Adapter needs to be Paired. Go into Android Bluetooth settings.
INFO 61.63800(s): Calling Connect
INFO 63.64100(s): Calling Connect
INFO 65.64300(s): Calling Connect
INFO 67.64500(s): Calling Connect
INFO 69.64700(s): Calling Connect
INFO 71.64900(s): Calling Connect
INFO 73.27500(s): Stopped runtime reads
INFO 73.27700(s): Connection closing: EFI Analytics 05
DEBUG 73.28100(s): LoggerMonitor::onBackPressed() called, exiting app
DEBUG 73.28800(s): LoggerMonitor::onPause() called
DEBUG 73.80100(s): LoggerMonitor::onStop() called
6/25/14 12:47:52 PM :Debug: ExtGPSManager.stop() ExternalGPS
DEBUG 115.89200(s): Installation Source: com.android.vending, com.efiAnalytics.shadowdash
DEBUG 115.89600(s): Installation source: com.android.vending
INFO 115.89700(s): Licensing managed by google
INFO 115.94800(s): License Validated by Google
DEBUG 115.94900(s): Cached EFI Activation of Google license validated.
DEBUG 115.94900(s): ShadowDashActivity::onCreate called
DEBUG 115.98300(s): ShadowDashActivity: viewSwitcher created
DEBUG 116.00300(s): ShadowDashActivity:: setContent
DEBUG 116.00400(s): ShadowDashActivity:: added home
DEBUG 116.00400(s): ShadowDashActivity:: got references
DEBUG 116.00400(s): ShadowDashActivity:: set Home dash
DEBUG 116.00500(s): ShadowDashActivity: created buttons
DEBUG 116.00500(s): ShadowDashActivity: readPrefs ??
DEBUG 116.00600(s): ShadowDashActivity: checkBtInitialization
DEBUG 116.00600(s): ShadowDashActivity: updateDeviceInfoDisplay()
DEBUG 116.00600(s): ShadowDashActivity: queued logs for upload
DEBUG 116.00700(s): ShadowDashActivity: gesture stuff
DEBUG 116.00800(s): ShadowDashActivity: set touch listeners
DEBUG 116.00900(s): ShadowDashActivity: checkExpiration()
DEBUG 116.01000(s): ShadowDashActivity: initDashboards()
INFO 116.01100(s): Calling Connect
DEBUG 116.01100(s): ShadowDashActivity: onCreate() DONE
DEBUG 116.01300(s): LoggerMonitor::onStart() called
DEBUG 116.01500(s): ShadowDashActivity: initializeWakeLock()
DEBUG 116.01500(s): LoggerMonitor::onResume() called
INFO 116.02600(s): Initializing GPS Manager
6/25/14 12:48:34 PM :Info: Initializing internal GPS
6/25/14 12:48:34 PM :Info: Internal GPS initialized
6/25/14 12:48:34 PM :Debug: ExtGPSManager.stop() ExternalGPS
6/25/14 12:48:34 PM :Debug: Typeface for 'Arial Normal' not found.
INFO 116.81900(s): Found FTDI Device 0
INFO 116.82100(s): No Prolific devices found.
INFO 118.01500(s): Calling Connect
INFO 120.01600(s): Calling Connect
INFO 122.01800(s): Calling Connect
INFO 122.82800(s): Selected Adapter needs to be Paired. Go into Android Bluetooth settings.
6/25/14 12:48:41 PM :Info: Toast: Selected Adapter needs to be Paired. Go into Android Bluetooth settings.
INFO 124.02000(s): Calling Connect
INFO 126.02200(s): Calling Connect
DEBUG 126.10900(s): LoggerMonitor::onPause() called
INFO 126.20600(s): Found FTDI Device 0
INFO 126.20900(s): No Prolific devices found.
INFO 127.57200(s): Creating Bluetooth Interface to connect to: efi analytics 01: 00:12:6F:27:94:32
INFO 127.57400(s): Connection closing: EFI Analytics 05
DEBUG 127.59500(s): LoggerMonitor::onResume() called
6/25/14 12:48:46 PM :Debug: ExtGPSManager.stop() ExternalGPS
INFO 128.09399(s): Calling Connect
INFO 128.09700(s): Connecting Attempt started
6/25/14 12:48:46 PM :Debug: Got BT Socket
6/25/14 12:48:46 PM :Debug: About to connect Socket
INFO 128.11200(s): Connection Attempt failed
INFO 128.42999(s): Found FTDI Device 0
INFO 128.43201(s): No Prolific devices found.
INFO 128.43401(s): Creating Bluetooth Interface to connect to: efi analytics 01: 00:12:6F:27:94:32
INFO 128.43600(s): Connection closing: efi analytics 01
INFO 130.11400(s): Calling Connect
INFO 130.11600(s): Connecting Attempt started
6/25/14 12:48:48 PM :Debug: Got BT Socket
6/25/14 12:48:48 PM :Debug: About to connect Socket
INFO 130.13300(s): Connection Attempt failed
INFO 132.13600(s): Calling Connect
INFO 132.13901(s): Connecting Attempt started
6/25/14 12:48:50 PM :Debug: Got BT Socket
6/25/14 12:48:50 PM :Debug: About to connect Socket
INFO 132.15900(s): Connection Attempt failed
INFO 134.16100(s): Calling Connect
INFO 134.16400(s): Connecting Attempt started
6/25/14 12:48:52 PM :Debug: Got BT Socket
6/25/14 12:48:52 PM :Debug: About to connect Socket
INFO 134.18401(s): Connection Attempt failed
INFO 136.18600(s): Calling Connect
INFO 136.18900(s): Connecting Attempt started
6/25/14 12:48:54 PM :Debug: Got BT Socket
6/25/14 12:48:54 PM :Debug: About to connect Socket
6/25/14 12:48:55 PM :Debug: Socket connected
INFO 137.08000(s): Connected to :efi analytics 01
INFO 137.08099(s): Connected
INFO 137.10899(s): Starting StartRuntime1403714935870
DEBUG 137.11800(s): config is null, going to interrogate
DEBUG 137.11900(s): StartRuntime1403714935870 about to interrogate 1
INFO 137.12000(s): Searching for Controller
6/25/14 12:48:55 PM :Info: Comm Read Thread Change! Old Thread:null, new Thread:StartRuntime1403714935870
DEBUG 197.22701(s): LoggerMonitor::onPause() called
DEBUG 197.26199(s): LoggerMonitor::onStop() called
DEBUG 197.46600(s): Installation Source: com.android.vending, com.efiAnalytics.shadowdash
DEBUG 197.47200(s): Installation source: com.android.vending
INFO 197.47200(s): Licensing managed by google
INFO 197.51801(s): License Validated by Google
DEBUG 197.51801(s): Cached EFI Activation of Google license validated.
DEBUG 197.51900(s): ShadowDashActivity::onCreate called
DEBUG 197.55499(s): ShadowDashActivity: viewSwitcher created
DEBUG 197.57899(s): ShadowDashActivity:: setContent
DEBUG 197.58000(s): ShadowDashActivity:: added home
DEBUG 197.58000(s): ShadowDashActivity:: got references
DEBUG 197.58000(s): ShadowDashActivity:: set Home dash
DEBUG 197.58099(s): ShadowDashActivity: created buttons
DEBUG 197.58099(s): ShadowDashActivity: readPrefs ??
DEBUG 197.58099(s): ShadowDashActivity: checkBtInitialization
DEBUG 197.58200(s): ShadowDashActivity: updateDeviceInfoDisplay()
DEBUG 197.58200(s): ShadowDashActivity: queued logs for upload
DEBUG 197.58200(s): ShadowDashActivity: gesture stuff
DEBUG 197.58200(s): ShadowDashActivity: set touch listeners
DEBUG 197.58299(s): ShadowDashActivity: checkExpiration()
DEBUG 197.58299(s): ShadowDashActivity: initDashboards()
DEBUG 197.58400(s): ShadowDashActivity: onCreate() DONE
DEBUG 197.58501(s): LoggerMonitor::onStart() called
DEBUG 197.58600(s): ShadowDashActivity: initializeWakeLock()
DEBUG 197.58600(s): LoggerMonitor::onResume() called
6/25/14 12:49:56 PM :Debug: ExtGPSManager.stop() ExternalGPS
6/25/14 12:49:56 PM :Debug: Typeface for 'Arial Normal' not found.
DEBUG 198.27499(s): LoggerMonitor::onPause() called
DEBUG 198.31300(s): LoggerMonitor::onStop() called
DEBUG 198.45599(s): Installation Source: com.android.vending, com.efiAnalytics.shadowdash
DEBUG 198.46001(s): Installation source: com.android.vending
INFO 198.46001(s): Licensing managed by google
INFO 198.52299(s): License Validated by Google
DEBUG 198.52299(s): Cached EFI Activation of Google license validated.
DEBUG 198.52400(s): ShadowDashActivity::onCreate called
DEBUG 198.55400(s): ShadowDashActivity: viewSwitcher created
DEBUG 198.57600(s): ShadowDashActivity:: setContent
DEBUG 198.57600(s): ShadowDashActivity:: added home
DEBUG 198.57700(s): ShadowDashActivity:: got references
DEBUG 198.57700(s): ShadowDashActivity:: set Home dash
DEBUG 198.57800(s): ShadowDashActivity: created buttons
DEBUG 198.57800(s): ShadowDashActivity: readPrefs ??
DEBUG 198.57800(s): ShadowDashActivity: checkBtInitialization
DEBUG 198.57800(s): ShadowDashActivity: updateDeviceInfoDisplay()
DEBUG 198.57899(s): ShadowDashActivity: queued logs for upload
DEBUG 198.57899(s): ShadowDashActivity: gesture stuff
DEBUG 198.57899(s): ShadowDashActivity: set touch listeners
DEBUG 198.57899(s): ShadowDashActivity: checkExpiration()
DEBUG 198.58000(s): ShadowDashActivity: initDashboards()
DEBUG 198.58099(s): ShadowDashActivity: onCreate() DONE
DEBUG 198.58200(s): LoggerMonitor::onStart() called
DEBUG 198.58200(s): ShadowDashActivity: initializeWakeLock()
DEBUG 198.58299(s): LoggerMonitor::onResume() called
6/25/14 12:49:57 PM :Debug: ExtGPSManager.stop() ExternalGPS
6/25/14 12:49:57 PM :Debug: Typeface for 'Arial Normal' not found.
INFO 214.88800(s): Stopped runtime reads
6/25/14 12:50:14 PM :Debug: ExtGPSManager.stop() ExternalGPS
Start time: Wed Jun 25 12:51:20 EDT 2014
INFO 0.00100(s):
DEBUG 0.00400(s): Starting ShadowDash Service
6/25/14 12:51:20 PM :Debug: Command Non-VolatileBytes for F resolved to: x46 F
6/25/14 12:51:20 PM :Debug: Command Non-VolatileBytes for I resolved to: x49 I
6/25/14 12:51:20 PM :Debug: Command Non-VolatileBytes for f resolved to: x66 f
DEBUG 21.33900(s): Installation Source: com.android.vending, com.efiAnalytics.shadowdash
DEBUG 21.35900(s): Installation source: com.android.vending
INFO 21.36000(s): Licensing managed by google
INFO 21.43400(s): License Validated by Google
DEBUG 21.43500(s): Cached EFI Activation of Google license validated.
DEBUG 21.43500(s): ShadowDashActivity::onCreate called
6/25/14 12:51:41 PM :Debug: Get LocationProvider
6/25/14 12:51:41 PM :Debug: locationProvider: gps
6/25/14 12:51:41 PM :Debug: bestProviderName: gps
6/25/14 12:51:41 PM :Info: GPSManager initialized
DEBUG 21.48200(s): ShadowDashActivity: viewSwitcher created
DEBUG 21.52500(s): ShadowDashActivity:: setContent
DEBUG 21.52500(s): ShadowDashActivity:: added home
DEBUG 21.52700(s): ShadowDashActivity:: got references
DEBUG 21.57600(s): ShadowDashActivity:: created home dash
DEBUG 21.57700(s): ShadowDashActivity:: set Home dash
DEBUG 21.57800(s): ShadowDashActivity: created buttons
DEBUG 21.57800(s): ShadowDashActivity: readPrefs ??
DEBUG 21.57900(s): ShadowDashActivity: checkBtInitialization
DEBUG 21.57900(s): ShadowDashActivity: updateDeviceInfoDisplay()
DEBUG 21.58000(s): ShadowDashActivity: queued logs for upload
DEBUG 21.58000(s): ShadowDashActivity: gesture stuff
DEBUG 21.58100(s): ShadowDashActivity: set touch listeners
DEBUG 21.58100(s): ShadowDashActivity: checkExpiration()
DEBUG 21.58400(s): ShadowDashActivity: initDashboards()
DEBUG 21.58500(s): ShadowDashActivity: addSavedDashboards()
DEBUG 21.58600(s): ShadowDashActivity: onCreate() DONE
DEBUG 21.59200(s): LoggerMonitor::onStart() called
DEBUG 21.59400(s): ShadowDashActivity: initializeWakeLock()
DEBUG 21.59400(s): LoggerMonitor::onResume() called
INFO 21.61800(s): Initializing GPS Manager
6/25/14 12:51:42 PM :Info: Initializing internal GPS
6/25/14 12:51:42 PM :Info: Internal GPS initialized
6/25/14 12:51:42 PM :Debug: ExtGPSManager.stop() ExternalGPS
INFO 21.80300(s): Time to read cached version of home_landscape.dash: 212.0
INFO 21.89000(s): Time to read cached version of home_portrait.dash: 86.0
DEBUG 21.94700(s): ShadowDashActivity: addSavedDashboards() complete: 362
6/25/14 12:51:42 PM :Debug: Typeface for 'Arial Normal' not found.
INFO 22.41000(s): Found FTDI Device 0
INFO 22.41700(s): No Prolific devices found.
INFO 22.42000(s): Creating Bluetooth Interface to connect to: efi analytics 01: 00:12:6F:27:94:32
INFO 24.58600(s): Calling Connect
INFO 24.58800(s): Connecting Attempt started
6/25/14 12:51:45 PM :Debug: Got BT Socket
6/25/14 12:51:45 PM :Debug: About to connect Socket
6/25/14 12:51:45 PM :Debug: Socket connected
INFO 25.49900(s): Connected to :efi analytics 01
INFO 25.50000(s): Connected
INFO 25.50300(s): Starting StartRuntime1403715105915
DEBUG 25.50900(s): config is null, going to interrogate
DEBUG 25.51000(s): StartRuntime1403715105915 about to interrogate 1
INFO 25.51000(s): Searching for Controller
6/25/14 12:51:45 PM :Info: Comm Read Thread Change! Old Thread:null, new Thread:StartRuntime1403715105915
INFO 73.59600(s): Stopped runtime reads
6/25/14 12:52:34 PM :Debug: ExtGPSManager.stop() ExternalGPS
Start time: Wed Jun 25 12:55:35 EDT 2014
INFO 0.00200(s):
DEBUG 0.03900(s): Starting ShadowDash Service
6/25/14 12:55:35 PM :Debug: Command Non-VolatileBytes for F resolved to: x46 F
6/25/14 12:55:35 PM :Debug: Command Non-VolatileBytes for I resolved to: x49 I
6/25/14 12:55:35 PM :Debug: Command Non-VolatileBytes for f resolved to: x66 f
DEBUG 0.08400(s): Installation Source: com.android.vending, com.efiAnalytics.shadowdash
DEBUG 0.09200(s): Installation source: com.android.vending
INFO 0.09300(s): Licensing managed by google
DEBUG 0.16900(s): ShadowDashActivity::onCreate called
6/25/14 12:55:36 PM :Debug: Get LocationProvider
6/25/14 12:55:36 PM :Debug: locationProvider: gps
6/25/14 12:55:36 PM :Debug: bestProviderName: gps
6/25/14 12:55:36 PM :Info: GPSManager initialized
DEBUG 0.23800(s): ShadowDashActivity: viewSwitcher created
DEBUG 0.29400(s): ShadowDashActivity:: setContent
DEBUG 0.29500(s): ShadowDashActivity:: added home
DEBUG 0.29500(s): ShadowDashActivity:: got references
DEBUG 0.34900(s): ShadowDashActivity:: created home dash
DEBUG 0.35000(s): ShadowDashActivity:: set Home dash
DEBUG 0.35200(s): ShadowDashActivity: created buttons
DEBUG 0.35200(s): ShadowDashActivity: readPrefs ??
DEBUG 0.35200(s): ShadowDashActivity: checkBtInitialization
DEBUG 0.35300(s): ShadowDashActivity: updateDeviceInfoDisplay()
DEBUG 0.35300(s): ShadowDashActivity: queued logs for upload
DEBUG 0.35400(s): ShadowDashActivity: gesture stuff
DEBUG 0.35400(s): ShadowDashActivity: set touch listeners
DEBUG 0.35500(s): ShadowDashActivity: checkExpiration()
DEBUG 0.35800(s): ShadowDashActivity: initDashboards()
DEBUG 0.35900(s): ShadowDashActivity: addSavedDashboards()
DEBUG 0.36000(s): ShadowDashActivity: onCreate() DONE
DEBUG 0.36200(s): LoggerMonitor::onStart() called
DEBUG 0.36200(s): ShadowDashActivity: initializeWakeLock()
DEBUG 0.36300(s): LoggerMonitor::onResume() called
INFO 0.38300(s): Initializing GPS Manager
6/25/14 12:55:36 PM :Info: Initializing internal GPS
6/25/14 12:55:36 PM :Info: Internal GPS initialized
6/25/14 12:55:36 PM :Debug: ExtGPSManager.stop() ExternalGPS
INFO 0.69300(s): Time to read cached version of home_landscape.dash: 331.0
INFO 0.95200(s): Time to read cached version of home_portrait.dash: 259.0
6/25/14 12:55:36 PM :Debug: Typeface for 'Arial Normal' not found.
DEBUG 1.04300(s): ShadowDashActivity: addSavedDashboards() complete: 684
INFO 1.17700(s): Found FTDI Device 0
INFO 1.18200(s): No Prolific devices found.
INFO 1.18700(s): Creating Bluetooth Interface to connect to: efi analytics 01: 00:12:6F:27:94:32
INFO 3.36100(s): Calling Connect
INFO 3.36400(s): Connecting Attempt started
6/25/14 12:55:39 PM :Debug: Got BT Socket
6/25/14 12:55:39 PM :Debug: About to connect Socket
INFO 3.57600(s): Checked for updates, none available
INFO 3.57700(s): Speed Test:19531
6/25/14 12:55:40 PM :Debug: Socket connected
INFO 4.62100(s): Connected to :efi analytics 01
INFO 4.62200(s): Connected
INFO 4.63600(s): Starting StartRuntime1403715340411
DEBUG 4.63700(s): config is null, going to interrogate
DEBUG 4.63700(s): StartRuntime1403715340411 about to interrogate 1
INFO 4.63800(s): Searching for Controller
6/25/14 12:55:40 PM :Info: Comm Read Thread Change! Old Thread:null, new Thread:StartRuntime1403715340411
INFO 4.89700(s): License Validated by Google
DEBUG 4.90000(s): Google license validated.
INFO 40.76400(s): Stopped runtime reads
6/25/14 12:56:17 PM :Debug: ExtGPSManager.stop() ExternalGPS
Shadow Dash MS 1.24 Started.
Start time: Wed Jun 25 12:56:58 EDT 2014
INFO 0.00100(s):
DEBUG 0.00600(s): Starting ShadowDash Service
6/25/14 12:56:58 PM :Debug: Command Non-VolatileBytes for F resolved to: x46 F
6/25/14 12:56:58 PM :Debug: Command Non-VolatileBytes for I resolved to: x49 I
6/25/14 12:56:58 PM :Debug: Command Non-VolatileBytes for f resolved to: x66 f
DEBUG 0.04200(s): Installation Source: null, com.efiAnalytics.shadowdash
DEBUG 0.04600(s): Installation source: null
INFO 0.04700(s): Licensing managed by EFI Analytics
INFO 0.06400(s): did:frankracing.naranjit4ce20fd8447b0d30, ba:android.bluetooth.BluetoothAdapter@411abc20
INFO 0.06700(s): did:frankracing.naranjit4ce20fd8447b0d30, ba:android.bluetooth.BluetoothAdapter@411abc20
DEBUG 0.06800(s): Server Activation Processor starting.
DEBUG 0.06800(s): Activation Request: com.efiAnalytics.b.b@411e9210
DEBUG 4.01700(s): Server Activation Processor got response. k+7/sW6Fl78T1AyLZ4mqxE4/bc19JYmxo0N1U5tqr3VGyMVfsju3HSGS9I+VtA1Oco7vKqIXNlMEG99pr4SD4pVX+6eKCUUesjkixoGQbBfsuuWdu7kdeSLdP5r8h7iSvytCwqawrBSAHz7M3voh2QScTDZPTY7IZptGjC7XOBQ20MoqIvXGXEnWejD3eW2bZVHcrAhW8SGNdWNjV1Dori9r16avjLw22aeZTwEySvbeKyY4jE/4pXBMSvzwGBs4s3Fevxah+34cxFyO4vt9cxSWjXOs2aRbnnGwMPIRXmwB/YRSV8WezgpIEPgUKQZK+f0Vxl2nlr9PmnVqRM/i6w==
DEBUG 4.01800(s): Server Activation Processor Notify().
INFO 4.01900(s): completed act after 3951
DEBUG 4.01900(s): Server Activation response: com.efiAnalytics.b.a@41244db0
INFO 4.02100(s): did:frankracing.naranjit4ce20fd8447b0d30, ba:android.bluetooth.BluetoothAdapter@411abc20
INFO 4.02700(s): Saved Activation key.
INFO 4.02800(s): License Validated by EFIA
DEBUG 4.03000(s): ShadowDashActivity::onCreate called
6/25/14 12:57:02 PM :Debug: Get LocationProvider
6/25/14 12:57:02 PM :Debug: locationProvider: gps
6/25/14 12:57:02 PM :Debug: bestProviderName: gps
6/25/14 12:57:02 PM :Info: GPSManager initialized
DEBUG 4.07300(s): ShadowDashActivity: viewSwitcher created
DEBUG 4.11300(s): ShadowDashActivity:: setContent
DEBUG 4.11300(s): ShadowDashActivity:: added home
DEBUG 4.11400(s): ShadowDashActivity:: got references
DEBUG 4.17000(s): ShadowDashActivity:: created home dash
DEBUG 4.17000(s): ShadowDashActivity:: set Home dash
DEBUG 4.17200(s): ShadowDashActivity: created buttons
DEBUG 4.17200(s): ShadowDashActivity: readPrefs ??
DEBUG 4.17300(s): ShadowDashActivity: checkBtInitialization
DEBUG 4.17300(s): ShadowDashActivity: updateDeviceInfoDisplay()
DEBUG 4.17300(s): ShadowDashActivity: queued logs for upload
DEBUG 4.17400(s): ShadowDashActivity: gesture stuff
DEBUG 4.17400(s): ShadowDashActivity: set touch listeners
DEBUG 4.17400(s): ShadowDashActivity: checkExpiration()
DEBUG 4.17700(s): ShadowDashActivity: initDashboards()
DEBUG 4.18000(s): ShadowDashActivity: onCreate() DONE
DEBUG 4.18100(s): LoggerMonitor::onStart() called
DEBUG 4.18200(s): ShadowDashActivity: initializeWakeLock()
DEBUG 4.18200(s): LoggerMonitor::onResume() called
DEBUG 4.18300(s): ShadowDashActivity: addSavedDashboards()
INFO 4.20400(s): Initializing GPS Manager
6/25/14 12:57:02 PM :Info: Initializing internal GPS
6/25/14 12:57:02 PM :Info: Internal GPS initialized
6/25/14 12:57:02 PM :Debug: ExtGPSManager.stop() ExternalGPS
INFO 4.34800(s): Time to read cached version of home_landscape.dash: 162.0
INFO 4.41600(s): Time to read cached version of home_portrait.dash: 66.0
DEBUG 4.48700(s): ShadowDashActivity: addSavedDashboards() complete: 307
6/25/14 12:57:03 PM :Debug: Typeface for 'Arial Normal' not found.
INFO 4.99900(s): Found FTDI Device 0
INFO 5.01500(s): No Prolific devices found.
INFO 5.01800(s): Creating Bluetooth Interface to connect to: efi analytics 01: 00:12:6F:27:94:32
INFO 7.17900(s): Calling Connect
INFO 7.18200(s): Connecting Attempt started
6/25/14 12:57:05 PM :Debug: Got BT Socket
6/25/14 12:57:05 PM :Debug: About to connect Socket
6/25/14 12:57:06 PM :Debug: Socket connected
INFO 8.14400(s): Connected to :efi analytics 01
INFO 8.14500(s): Connected
INFO 8.14900(s): Starting StartRuntime1403715426459
DEBUG 8.15100(s): config is null, going to interrogate
DEBUG 8.15200(s): StartRuntime1403715426459 about to interrogate 1
INFO 8.15200(s): Searching for Controller
6/25/14 12:57:06 PM :Info: Comm Read Thread Change! Old Thread:null, new Thread:StartRuntime1403715426459
6/25/14 12:57:24 PM :Debug: Downloading file: ShadowDashMS_Beta_1.25.apk, size:9132919
6/25/14 12:57:53 PM :Debug: downloaded all 9132919
6/25/14 12:57:53 PM :Debug: closed streams
6/25/14 12:57:53 PM :Debug: Renamed file to: /storage/emulated/0/.efiAnalytics/ShadowDashMS_Beta_1.25.apk
Start time: Wed Jun 25 12:58:11 EDT 2014
INFO 0.00100(s):
6/25/14 12:58:11 PM :Debug: Command Non-VolatileBytes for F resolved to: x46 F
6/25/14 12:58:11 PM :Debug: Command Non-VolatileBytes for I resolved to: x49 I
6/25/14 12:58:11 PM :Debug: Command Non-VolatileBytes for f resolved to: x66 f
DEBUG 0.04700(s): Installation Source: null, com.efiAnalytics.shadowdash
DEBUG 0.05200(s): Installation source: null
INFO 0.05300(s): Licensing managed by EFI Analytics
INFO 0.06800(s): did:frankracing.naranjit4ce20fd8447b0d30, ba:android.bluetooth.BluetoothAdapter@411af280
INFO 0.06900(s): License Validated by EFIA
DEBUG 0.06900(s): ShadowDashActivity::onCreate called
6/25/14 12:58:11 PM :Debug: Get LocationProvider
6/25/14 12:58:11 PM :Debug: locationProvider: gps
6/25/14 12:58:11 PM :Debug: bestProviderName: gps
6/25/14 12:58:11 PM :Info: GPSManager initialized
DEBUG 0.12300(s): ShadowDashActivity: viewSwitcher created
DEBUG 0.17300(s): ShadowDashActivity:: setContent
DEBUG 0.17300(s): ShadowDashActivity:: added home
DEBUG 0.17400(s): ShadowDashActivity:: got references
DEBUG 0.22900(s): ShadowDashActivity:: created home dash
DEBUG 0.23000(s): ShadowDashActivity:: set Home dash
DEBUG 0.23100(s): ShadowDashActivity: created buttons
DEBUG 0.23100(s): ShadowDashActivity: readPrefs ??
DEBUG 0.23100(s): ShadowDashActivity: checkBtInitialization
DEBUG 0.23200(s): ShadowDashActivity: updateDeviceInfoDisplay()
DEBUG 0.23200(s): ShadowDashActivity: queued logs for upload
DEBUG 0.23300(s): ShadowDashActivity: gesture stuff
DEBUG 0.23300(s): ShadowDashActivity: set touch listeners
DEBUG 0.23400(s): ShadowDashActivity: checkExpiration()
DEBUG 0.24000(s): ShadowDashActivity: initDashboards()
DEBUG 0.24300(s): ShadowDashActivity: addSavedDashboards()
DEBUG 0.24500(s): ShadowDashActivity: onCreate() DONE
DEBUG 0.24700(s): LoggerMonitor::onStart() called
DEBUG 0.24800(s): ShadowDashActivity: initializeWakeLock()
DEBUG 0.24900(s): LoggerMonitor::onResume() called
INFO 0.29500(s): Initializing GPS Manager
6/25/14 12:58:11 PM :Info: Initializing internal GPS
6/25/14 12:58:11 PM :Info: Internal GPS initialized
6/25/14 12:58:11 PM :Debug: ExtGPSManager.stop() ExternalGPS
INFO 0.39900(s): Time to read cached version of home_landscape.dash: 153.0
INFO 0.46600(s): Time to read cached version of home_portrait.dash: 66.0
DEBUG 0.50600(s): ShadowDashActivity: addSavedDashboards() complete: 263
6/25/14 12:58:12 PM :Debug: Typeface for 'Arial Normal' not found.
INFO 1.08500(s): Found FTDI Device 0
INFO 1.09300(s): No Prolific devices found.
INFO 1.10000(s): Creating Bluetooth Interface to connect to: efi analytics 01: 00:12:6F:27:94:32
INFO 3.24500(s): Calling Connect
INFO 3.25500(s): Connecting Attempt started
6/25/14 12:58:14 PM :Debug: Got BT Socket
6/25/14 12:58:14 PM :Debug: About to connect Socket
6/25/14 12:58:15 PM :Debug: Socket connected
INFO 4.27800(s): Connected to :efi analytics 01
INFO 4.27900(s): Connected
INFO 4.28100(s): Starting StartRuntime1403715495826
DEBUG 4.28300(s): config is null, going to interrogate
DEBUG 4.28400(s): StartRuntime1403715495826 about to interrogate 1
INFO 4.28600(s): Searching for Controller
6/25/14 12:58:15 PM :Info: Comm Read Thread Change! Old Thread:null, new Thread:StartRuntime1403715495826
INFO 5.69900(s): Checked for updates, none available
INFO 5.70000(s): Speed Test:19531
INFO 24.43800(s): Stopped runtime reads
6/25/14 12:58:36 PM :Debug: ExtGPSManager.stop() ExternalGPS
Start time: Wed Jun 25 12:59:27 EDT 2014
INFO 0.00400(s):
DEBUG 0.03400(s): Starting ShadowDash Service
6/25/14 12:59:28 PM :Debug: Command Non-VolatileBytes for F resolved to: x46 F
6/25/14 12:59:28 PM :Debug: Command Non-VolatileBytes for I resolved to: x49 I
6/25/14 12:59:28 PM :Debug: Command Non-VolatileBytes for f resolved to: x66 f
DEBUG 0.18200(s): Installation Source: null, com.efiAnalytics.shadowdash
DEBUG 0.20400(s): Installation source: null
INFO 0.20400(s): Licensing managed by EFI Analytics
INFO 0.22700(s): did:frankracing.naranjit4ce20fd8447b0d30, ba:android.bluetooth.BluetoothAdapter@41280f20
INFO 0.22800(s): License Validated by EFIA
DEBUG 0.22800(s): ShadowDashActivity::onCreate called
6/25/14 12:59:28 PM :Debug: Get LocationProvider
6/25/14 12:59:28 PM :Debug: locationProvider: gps
6/25/14 12:59:28 PM :Debug: bestProviderName: gps
6/25/14 12:59:28 PM :Info: GPSManager initialized
DEBUG 0.29700(s): ShadowDashActivity: viewSwitcher created
DEBUG 0.35000(s): ShadowDashActivity:: setContent
DEBUG 0.35000(s): ShadowDashActivity:: added home
DEBUG 0.35100(s): ShadowDashActivity:: got references
DEBUG 0.41800(s): ShadowDashActivity:: created home dash
DEBUG 0.41900(s): ShadowDashActivity:: set Home dash
DEBUG 0.42000(s): ShadowDashActivity: created buttons
DEBUG 0.42000(s): ShadowDashActivity: readPrefs ??
DEBUG 0.42000(s): ShadowDashActivity: checkBtInitialization
DEBUG 0.42100(s): ShadowDashActivity: updateDeviceInfoDisplay()
DEBUG 0.42100(s): ShadowDashActivity: queued logs for upload
DEBUG 0.42100(s): ShadowDashActivity: gesture stuff
DEBUG 0.42200(s): ShadowDashActivity: set touch listeners
DEBUG 0.42400(s): ShadowDashActivity: checkExpiration()
DEBUG 0.42700(s): ShadowDashActivity: initDashboards()
DEBUG 0.43000(s): ShadowDashActivity: onCreate() DONE
DEBUG 0.43100(s): LoggerMonitor::onStart() called
DEBUG 0.43200(s): ShadowDashActivity: initializeWakeLock()
DEBUG 0.43200(s): LoggerMonitor::onResume() called
DEBUG 0.43300(s): ShadowDashActivity: addSavedDashboards()
INFO 0.46400(s): Initializing GPS Manager
6/25/14 12:59:28 PM :Info: Initializing internal GPS
6/25/14 12:59:28 PM :Info: Internal GPS initialized
6/25/14 12:59:28 PM :Debug: ExtGPSManager.stop() ExternalGPS
INFO 0.65400(s): Time to read cached version of home_landscape.dash: 217.0
INFO 0.86400(s): Time to read cached version of home_portrait.dash: 195.0
6/25/14 12:59:29 PM :Debug: Typeface for 'Arial Normal' not found.
DEBUG 1.22800(s): ShadowDashActivity: addSavedDashboards() complete: 794
INFO 1.25400(s): Found FTDI Device 0
INFO 1.26000(s): No Prolific devices found.
6/25/14 12:59:29 PM :Info: Found EFI Analytics BT Adapter: efi analytics 01
INFO 1.27100(s): Creating Bluetooth Interface to connect to: efi analytics 01: 00:12:6F:27:94:32
INFO 3.05300(s): Checked for updates, none available
INFO 3.05500(s): Speed Test:19531
INFO 3.43000(s): Calling Connect
INFO 3.43700(s): Connecting Attempt started
6/25/14 12:59:31 PM :Debug: Got BT Socket
6/25/14 12:59:31 PM :Debug: About to connect Socket
DEBUG 4.76800(s): LoggerMonitor::onPause() called
DEBUG 4.82000(s): LoggerMonitor::onStop() called
6/25/14 12:59:33 PM :Debug: Socket connected
INFO 5.06800(s): Connected to :efi analytics 01
INFO 5.06900(s): Connected
DEBUG 5.11200(s): Installation Source: null, com.efiAnalytics.shadowdash
DEBUG 5.12000(s): Installation source: null
INFO 5.12000(s): Licensing managed by EFI Analytics
INFO 5.13900(s): did:frankracing.naranjit4ce20fd8447b0d30, ba:android.bluetooth.BluetoothAdapter@41280f20
INFO 5.14000(s): License Validated by EFIA
DEBUG 5.14100(s): ShadowDashActivity::onCreate called
DEBUG 5.19700(s): ShadowDashActivity: viewSwitcher created
DEBUG 5.26200(s): ShadowDashActivity:: setContent
DEBUG 5.26200(s): ShadowDashActivity:: added home
DEBUG 5.26300(s): ShadowDashActivity:: got references
DEBUG 5.26400(s): ShadowDashActivity:: set Home dash
DEBUG 5.26900(s): ShadowDashActivity: created buttons
DEBUG 5.27000(s): ShadowDashActivity: readPrefs ??
DEBUG 5.27300(s): ShadowDashActivity: checkBtInitialization
DEBUG 5.27300(s): ShadowDashActivity: updateDeviceInfoDisplay()
DEBUG 5.27400(s): ShadowDashActivity: queued logs for upload
DEBUG 5.27400(s): ShadowDashActivity: gesture stuff
DEBUG 5.27400(s): ShadowDashActivity: set touch listeners
DEBUG 5.27500(s): ShadowDashActivity: checkExpiration()
DEBUG 5.27500(s): ShadowDashActivity: initDashboards()
DEBUG 5.27700(s): ShadowDashActivity: onCreate() DONE
DEBUG 5.28600(s): LoggerMonitor::onStart() called
DEBUG 5.29000(s): ShadowDashActivity: initializeWakeLock()
DEBUG 5.29400(s): LoggerMonitor::onResume() called
6/25/14 12:59:33 PM :Debug: ExtGPSManager.stop() ExternalGPS
6/25/14 12:59:33 PM :Debug: Typeface for 'Arial Normal' not found.
DEBUG 11.83600(s): LoggerMonitor::onPause() called
DEBUG 11.89100(s): LoggerMonitor::onStop() called
DEBUG 11.99500(s): Installation Source: null, com.efiAnalytics.shadowdash
DEBUG 11.99700(s): Installation source: null
INFO 11.99800(s): Licensing managed by EFI Analytics
INFO 12.01100(s): did:frankracing.naranjit4ce20fd8447b0d30, ba:android.bluetooth.BluetoothAdapter@41280f20
INFO 12.01200(s): License Validated by EFIA
DEBUG 12.01300(s): ShadowDashActivity::onCreate called
DEBUG 12.05600(s): ShadowDashActivity: viewSwitcher created
DEBUG 12.09400(s): ShadowDashActivity:: setContent
DEBUG 12.09500(s): ShadowDashActivity:: added home
DEBUG 12.09600(s): ShadowDashActivity:: got references
DEBUG 12.09700(s): ShadowDashActivity:: set Home dash
DEBUG 12.10100(s): ShadowDashActivity: created buttons
DEBUG 12.10200(s): ShadowDashActivity: readPrefs ??
DEBUG 12.10200(s): ShadowDashActivity: checkBtInitialization
DEBUG 12.10300(s): ShadowDashActivity: updateDeviceInfoDisplay()
DEBUG 12.10400(s): ShadowDashActivity: queued logs for upload
DEBUG 12.10400(s): ShadowDashActivity: gesture stuff
DEBUG 12.10400(s): ShadowDashActivity: set touch listeners
DEBUG 12.10500(s): ShadowDashActivity: checkExpiration()
DEBUG 12.10500(s): ShadowDashActivity: initDashboards()
DEBUG 12.10700(s): ShadowDashActivity: onCreate() DONE
DEBUG 12.10900(s): LoggerMonitor::onStart() called
DEBUG 12.11000(s): ShadowDashActivity: initializeWakeLock()
DEBUG 12.11000(s): LoggerMonitor::onResume() called
6/25/14 12:59:40 PM :Debug: ExtGPSManager.stop() ExternalGPS
6/25/14 12:59:40 PM :Debug: Typeface for 'Arial Normal' not found.
INFO 71.94000(s): Connection closing: efi analytics 01
INFO 79.90200(s): Stopped runtime reads
INFO 79.90500(s): Connection closing: efi analytics 01
DEBUG 79.91000(s): LoggerMonitor::onBackPressed() called, exiting app
DEBUG 79.91300(s): LoggerMonitor::onPause() called
DEBUG 80.44500(s): LoggerMonitor::onStop() called
6/25/14 1:00:48 PM :Debug: ExtGPSManager.stop() ExternalGPS
Start time: Wed Jun 25 13:01:04 EDT 2014
INFO 0.00100(s):
6/25/14 1:01:04 PM :Debug: Command Non-VolatileBytes for F resolved to: x46 F
6/25/14 1:01:04 PM :Debug: Command Non-VolatileBytes for I resolved to: x49 I
6/25/14 1:01:04 PM :Debug: Command Non-VolatileBytes for f resolved to: x66 f
DEBUG 0.04900(s): Installation source: null
INFO 0.05000(s): Licensing managed by EFI Analytics
INFO 0.06500(s): did:frankracing.naranjit4ce20fd8447b0d30, ba:android.bluetooth.BluetoothAdapter@4127b310
INFO 0.06600(s): License Validated by EFIA
DEBUG 0.06700(s): ShadowDashActivity::onCreate called
6/25/14 1:01:04 PM :Debug: Get LocationProvider
6/25/14 1:01:04 PM :Debug: locationProvider: gps
6/25/14 1:01:04 PM :Debug: bestProviderName: gps
6/25/14 1:01:04 PM :Info: GPSManager initialized
DEBUG 0.11300(s): ShadowDashActivity: viewSwitcher created
DEBUG 0.14900(s): ShadowDashActivity:: setContent
DEBUG 0.15000(s): ShadowDashActivity:: added home
DEBUG 0.15100(s): ShadowDashActivity:: got references
DEBUG 0.20000(s): ShadowDashActivity:: created home dash
DEBUG 0.20100(s): ShadowDashActivity:: set Home dash
DEBUG 0.20200(s): ShadowDashActivity: created buttons
DEBUG 0.20200(s): ShadowDashActivity: readPrefs ??
DEBUG 0.20200(s): ShadowDashActivity: checkBtInitialization
DEBUG 0.20300(s): ShadowDashActivity: updateDeviceInfoDisplay()
DEBUG 0.20300(s): ShadowDashActivity: queued logs for upload
DEBUG 0.20400(s): ShadowDashActivity: gesture stuff
DEBUG 0.20400(s): ShadowDashActivity: set touch listeners
DEBUG 0.20500(s): ShadowDashActivity: checkExpiration()
DEBUG 0.21000(s): ShadowDashActivity: initDashboards()
DEBUG 0.21100(s): ShadowDashActivity: addSavedDashboards()
DEBUG 0.21200(s): ShadowDashActivity: onCreate() DONE
DEBUG 0.21400(s): LoggerMonitor::onStart() called
DEBUG 0.21500(s): ShadowDashActivity: initializeWakeLock()
DEBUG 0.21600(s): LoggerMonitor::onResume() called
INFO 0.23800(s): Initializing GPS Manager
6/25/14 1:01:04 PM :Info: Initializing internal GPS
6/25/14 1:01:04 PM :Info: Internal GPS initialized
6/25/14 1:01:04 PM :Debug: ExtGPSManager.stop() ExternalGPS
INFO 0.41400(s): Time to read cached version of home_landscape.dash: 198.0
INFO 0.51300(s): Time to read cached version of home_portrait.dash: 98.0
DEBUG 0.65200(s): ShadowDashActivity: addSavedDashboards() complete: 440
6/25/14 1:01:05 PM :Debug: Typeface for 'Arial Normal' not found.
INFO 1.04000(s): Found FTDI Device 0
INFO 1.05000(s): No Prolific devices found.
6/25/14 1:01:05 PM :Info: Found EFI Analytics BT Adapter: efi analytics 01
INFO 1.05800(s): Creating Bluetooth Interface to connect to: efi analytics 01: 00:12:6F:27:94:32
INFO 3.21300(s): Calling Connect
INFO 3.21800(s): Connecting Attempt started
6/25/14 1:01:07 PM :Debug: Got BT Socket
6/25/14 1:01:07 PM :Debug: About to connect Socket
6/25/14 1:01:08 PM :Debug: Socket connected
INFO 4.20700(s): Connected to :efi analytics 01
INFO 4.20800(s): Connected
INFO 4.21200(s): Starting StartRuntime1403715668758
DEBUG 4.21400(s): config is null, going to interrogate
DEBUG 4.21800(s): StartRuntime1403715668758 about to interrogate 1
INFO 4.21800(s): Searching for Controller
6/25/14 1:01:08 PM :Info: Comm Read Thread Change! Old Thread:null, new Thread:StartRuntime1403715668758
INFO 4.59900(s): Checked for updates, none available
INFO 4.59900(s): Speed Test:19531
DEBUG 49.48600(s): LoggerMonitor::onPause() called
DEBUG 49.50100(s): LoggerMonitor::onStop() called
DEBUG 49.60500(s): Installation Source: null, com.efiAnalytics.shadowdash
DEBUG 49.61100(s): Installation source: null
INFO 49.61200(s): Licensing managed by EFI Analytics
INFO 49.63000(s): did:frankracing.naranjit4ce20fd8447b0d30, ba:android.bluetooth.BluetoothAdapter@4127b310
INFO 49.63100(s): License Validated by EFIA
DEBUG 49.63100(s): ShadowDashActivity::onCreate called
DEBUG 49.66800(s): ShadowDashActivity: viewSwitcher created
DEBUG 49.70200(s): ShadowDashActivity:: setContent
DEBUG 49.70200(s): ShadowDashActivity:: added home
DEBUG 49.70400(s): ShadowDashActivity:: got references
DEBUG 49.70400(s): ShadowDashActivity:: set Home dash
DEBUG 49.70500(s): ShadowDashActivity: created buttons
DEBUG 49.70500(s): ShadowDashActivity: readPrefs ??
DEBUG 49.70500(s): ShadowDashActivity: checkBtInitialization
DEBUG 49.70600(s): ShadowDashActivity: updateDeviceInfoDisplay()
DEBUG 49.70600(s): ShadowDashActivity: queued logs for upload
DEBUG 49.70600(s): ShadowDashActivity: gesture stuff
DEBUG 49.70700(s): ShadowDashActivity: set touch listeners
DEBUG 49.70700(s): ShadowDashActivity: checkExpiration()
DEBUG 49.70800(s): ShadowDashActivity: initDashboards()
DEBUG 49.70800(s): ShadowDashActivity: onCreate() DONE
DEBUG 49.70900(s): LoggerMonitor::onStart() called
DEBUG 49.71000(s): ShadowDashActivity: initializeWakeLock()
DEBUG 49.71100(s): LoggerMonitor::onResume() called
6/25/14 1:01:54 PM :Debug: ExtGPSManager.stop() ExternalGPS
6/25/14 1:01:54 PM :Debug: Typeface for 'Arial Normal' not found.
DEBUG 51.62300(s): LoggerMonitor::onPause() called
DEBUG 51.63900(s): LoggerMonitor::onStop() called
DEBUG 51.75000(s): Installation Source: null, com.efiAnalytics.shadowdash
DEBUG 51.75500(s): Installation source: null
INFO 51.75600(s): Licensing managed by EFI Analytics
INFO 51.77000(s): did:frankracing.naranjit4ce20fd8447b0d30, ba:android.bluetooth.BluetoothAdapter@4127b310
INFO 51.77100(s): License Validated by EFIA
DEBUG 51.77100(s): ShadowDashActivity::onCreate called
DEBUG 51.80600(s): ShadowDashActivity: viewSwitcher created
DEBUG 51.84800(s): ShadowDashActivity:: setContent
DEBUG 51.84800(s): ShadowDashActivity:: added home
DEBUG 51.84900(s): ShadowDashActivity:: got references
DEBUG 51.84900(s): ShadowDashActivity:: set Home dash
DEBUG 51.85000(s): ShadowDashActivity: created buttons
DEBUG 51.85000(s): ShadowDashActivity: readPrefs ??
DEBUG 51.85000(s): ShadowDashActivity: checkBtInitialization
DEBUG 51.85000(s): ShadowDashActivity: updateDeviceInfoDisplay()
DEBUG 51.85100(s): ShadowDashActivity: queued logs for upload
DEBUG 51.85100(s): ShadowDashActivity: gesture stuff
DEBUG 51.85100(s): ShadowDashActivity: set touch listeners
DEBUG 51.85200(s): ShadowDashActivity: checkExpiration()
DEBUG 51.85200(s): ShadowDashActivity: initDashboards()
DEBUG 51.85300(s): ShadowDashActivity: onCreate() DONE
DEBUG 51.85400(s): LoggerMonitor::onStart() called
DEBUG 51.85400(s): ShadowDashActivity: initializeWakeLock()
DEBUG 51.85500(s): LoggerMonitor::onResume() called
6/25/14 1:01:56 PM :Debug: ExtGPSManager.stop() ExternalGPS
6/25/14 1:01:56 PM :Debug: Typeface for 'Arial Normal' not found.
INFO 67.77000(s): Stopped runtime reads
6/25/14 1:02:13 PM :Debug: ExtGPSManager.stop() ExternalGPS
DEBUG 103.15600(s): Failed to get signature
INFO 106.17600(s): Stopped runtime reads
INFO 106.17700(s): Failed to detect firmware signature
INFO 106.17800(s): StartRuntime1403715668758 ControllerNotFoundException
INFO 106.17900(s): Opened Connection, but adapter unable to get response from controller
6/25/14 1:02:50 PM :Info: Toast: Opened Connection, but adapter unable to get response from controller
INFO 106.20700(s): Controller Not Found
INFO 106.20800(s): StartRuntime1403715668758 about to sleep 2000
INFO 106.45500(s): Connection closing: efi analytics 01
INFO 106.45900(s): StartRuntime1403715668758 keepTrying false, should die
INFO 106.46900(s): StartRuntime1403715668758 finished
DEBUG 106.48400(s): LoggerMonitor::onBackPressed() called, exiting app
DEBUG 106.49100(s): LoggerMonitor::onPause() called
DEBUG 106.55200(s): LoggerMonitor::onStop() called
6/25/14 1:02:51 PM :Debug: ExtGPSManager.stop() ExternalGPS
DEBUG 204.79900(s): Installation Source: null, com.efiAnalytics.shadowdash
DEBUG 204.80000(s): Installation source: null
INFO 204.80099(s): Licensing managed by EFI Analytics
INFO 204.80901(s): did:frankracing.naranjit4ce20fd8447b0d30, ba:android.bluetooth.BluetoothAdapter@4127b310
INFO 204.81000(s): License Validated by EFIA
DEBUG 204.81100(s): ShadowDashActivity::onCreate called
DEBUG 204.84599(s): ShadowDashActivity: viewSwitcher created
DEBUG 204.86600(s): ShadowDashActivity:: setContent
DEBUG 204.86700(s): ShadowDashActivity:: added home
DEBUG 204.86700(s): ShadowDashActivity:: got references
DEBUG 204.86700(s): ShadowDashActivity:: set Home dash
DEBUG 204.87000(s): ShadowDashActivity: created buttons
DEBUG 204.87100(s): ShadowDashActivity: readPrefs ??
DEBUG 204.87100(s): ShadowDashActivity: checkBtInitialization
DEBUG 204.87199(s): ShadowDashActivity: updateDeviceInfoDisplay()
DEBUG 204.87199(s): ShadowDashActivity: queued logs for upload
DEBUG 204.87199(s): ShadowDashActivity: gesture stuff
DEBUG 204.87300(s): ShadowDashActivity: set touch listeners
DEBUG 204.87300(s): ShadowDashActivity: checkExpiration()
DEBUG 204.87399(s): ShadowDashActivity: initDashboards()
INFO 204.87500(s): Calling Connect
DEBUG 204.87601(s): ShadowDashActivity: onCreate() DONE
INFO 204.87700(s): Connecting Attempt started
DEBUG 204.87801(s): LoggerMonitor::onStart() called
DEBUG 204.87801(s): ShadowDashActivity: initializeWakeLock()
DEBUG 204.87900(s): LoggerMonitor::onResume() called
6/25/14 1:04:29 PM :Debug: Got BT Socket
6/25/14 1:04:29 PM :Debug: About to connect Socket
INFO 204.89301(s): Connection Attempt failed
INFO 204.89799(s): Initializing GPS Manager
6/25/14 1:04:29 PM :Info: Initializing internal GPS
6/25/14 1:04:29 PM :Info: Internal GPS initialized
6/25/14 1:04:29 PM :Debug: ExtGPSManager.stop() ExternalGPS
6/25/14 1:04:29 PM :Debug: Typeface for 'Arial Normal' not found.
INFO 205.68401(s): Found FTDI Device 0
INFO 205.68600(s): No Prolific devices found.
INFO 205.68800(s): Creating Bluetooth Interface to connect to: efi analytics 01: 00:12:6F:27:94:32
INFO 205.68900(s): Connection closing: efi analytics 01
INFO 206.89700(s): Calling Connect
INFO 206.89799(s): Connecting Attempt started
6/25/14 1:04:31 PM :Debug: Got BT Socket
6/25/14 1:04:31 PM :Debug: About to connect Socket
INFO 206.91200(s): Connection Attempt failed
INFO 208.91400(s): Calling Connect
INFO 208.91600(s): Connecting Attempt started
6/25/14 1:04:33 PM :Debug: Got BT Socket
6/25/14 1:04:33 PM :Debug: About to connect Socket
INFO 208.93800(s): Connection Attempt failed
INFO 210.94000(s): Calling Connect
INFO 210.94299(s): Connecting Attempt started
6/25/14 1:04:35 PM :Debug: Got BT Socket
6/25/14 1:04:35 PM :Debug: About to connect Socket
INFO 210.96300(s): Connection Attempt failed
INFO 212.96400(s): Calling Connect
INFO 212.96700(s): Connecting Attempt started
6/25/14 1:04:37 PM :Debug: Got BT Socket
6/25/14 1:04:37 PM :Debug: About to connect Socket
6/25/14 1:04:38 PM :Debug: Socket connected
INFO 213.95599(s): Connected to :efi analytics 01
INFO 213.95700(s): Connected
INFO 213.95900(s): Starting StartRuntime1403715878506
DEBUG 213.96400(s): config is null, going to interrogate
DEBUG 213.96500(s): StartRuntime1403715878506 about to interrogate 1
INFO 213.96500(s): Searching for Controller
6/25/14 1:04:38 PM :Info: Comm Read Thread Change! Old Thread:StartRuntime1403715668758, new Thread:StartRuntime1403715878506
INFO 247.35899(s): Stopped runtime reads
6/25/14 1:05:12 PM :Debug: ExtGPSManager.stop() ExternalGPS
DEBUG 290.50800(s): Failed to get signature
INFO 293.51401(s): Stopped runtime reads
INFO 293.51501(s): Failed to detect firmware signature
INFO 293.51501(s): StartRuntime1403715878506 ControllerNotFoundException
INFO 293.51599(s): Opened Connection, but adapter unable to get response from controller
6/25/14 1:05:58 PM :Info: Toast: Opened Connection, but adapter unable to get response from controller
INFO 293.51700(s): Controller Not Found
INFO 293.51700(s): StartRuntime1403715878506 about to sleep 2000
INFO 293.56900(s): Connection closing: efi analytics 01
INFO 293.57101(s): StartRuntime1403715878506 keepTrying false, should die
INFO 293.57101(s): StartRuntime1403715878506 finished
DEBUG 293.57599(s): LoggerMonitor::onBackPressed() called, exiting app
DEBUG 293.57901(s): LoggerMonitor::onPause() called
DEBUG 293.59601(s): LoggerMonitor::onStop() called
6/25/14 1:06:17 PM :Debug: ExtGPSManager.stop() ExternalGPS
Are you able to connect with your other devices using the new BT Adapter?
I tried in a car that I intelled it before and is working fine with a microsquirt 3.25 firmware and shadow dash 1.22 and it do not conect with the acer tablet but it connect with the Samsung galaxy tabletLT401Vette wrote:Are you able to connect with your other devices using the new BT Adapter?
