shadow dash cant find controller firmware 3.30
Hi, I have a problem connecting to a microsquirt with 3.30 code.With my cellphone it connects and works fine ,but, with my tablet ,acer 7in,it conect to the Bluetooth adapter but says serching for controller and noting happens after that.Thanks in advance
Frank Racing,Naranjito Puerto Rico,installations and tuning solutions
FrankRacing.Naranjito@gmail.com
Re: shadow dash cant find controller firmware 3.30
Are you certain it is connecting to the BT Adapter?
The plug icon goes green?
Yes it goes greenLT401Vette wrote:Are you certain it is connecting to the BT Adapter?
I copy all the files from my phone to my tablet with a laptop and still Says searching for controller.I tested other firmware and still the same.I also tested different vercions of shadow dash but same result...
I have to buy a new version of shadow dash for every phone or tablet I use or I can use the same registration?Because I'm using the same registration code on the phone and tablet
The same registration on up to 3 devices.
what you can think we can do to fix this problemLT401Vette wrote:The same registration on up to 3 devices.
Are you using version 1.24?
Yes,I tried 1.0,1.19,1.23,1.24,I will buy another shadow dash registration to see if that is the problem because I dont kow for sure how many devices I have registeredLT401Vette wrote:Are you using version 1.24?
It will only count a device once no matter how many times you uninstall and install. It will tell you if there is a problem.Yes,I tried 1.0,1.19,1.23,1.24,I will buy another shadow dash registration to see if that is the problem because I dont kow for sure how many devices I have registered
It should connect even without the registration, but it will say Demo Mode and disconnect after a short period.
Perhaps send / post the appDebug.txt from it.
Is this?LT401Vette wrote:It will only count a device once no matter how many times you uninstall and install. It will tell you if there is a problem.Yes,I tried 1.0,1.19,1.23,1.24,I will buy another shadow dash registration to see if that is the problem because I dont kow for sure how many devices I have registered
Code: Select all
Android Version: 4.2.2
INFO 0.00100(s):
DEBUG 0.00500(s): Starting ShadowDash Service
5/7/14 9:47:13 AM :Debug: Command Non-VolatileBytes for F resolved to: x46 F
5/7/14 9:47:13 AM :Debug: Command Non-VolatileBytes for I resolved to: x49 I
5/7/14 9:47:13 AM :Debug: Command Non-VolatileBytes for f resolved to: x66 f
DEBUG 0.04400(s): Installation Source: null, com.efiAnalytics.shadowdash
DEBUG 0.04900(s): Installation source: null
INFO 0.04900(s): Licensing managed by EFI Analytics
INFO 0.06400(s): License Validated by EFIA
DEBUG 0.06500(s): ShadowDashActivity::onCreate called
5/7/14 9:47:13 AM :Debug: Get LocationProvider
5/7/14 9:47:13 AM :Debug: locationProvider: gps
5/7/14 9:47:13 AM :Debug: bestProviderName: gps
5/7/14 9:47:13 AM :Info: GPSManager initialized
DEBUG 0.11400(s): ShadowDashActivity: viewSwitcher created
DEBUG 0.15500(s): ShadowDashActivity:: setContent
DEBUG 0.15500(s): ShadowDashActivity:: added home
DEBUG 0.15600(s): ShadowDashActivity:: got references
DEBUG 0.20500(s): ShadowDashActivity:: created home dash
DEBUG 0.20600(s): ShadowDashActivity:: set Home dash
DEBUG 0.20700(s): ShadowDashActivity: created buttons
DEBUG 0.20700(s): ShadowDashActivity: readPrefs ??
DEBUG 0.20800(s): ShadowDashActivity: checkBtInitialization
DEBUG 0.20800(s): ShadowDashActivity: updateDeviceInfoDisplay()
DEBUG 0.20800(s): ShadowDashActivity: queued logs for upload
DEBUG 0.20900(s): ShadowDashActivity: gesture stuff
DEBUG 0.20900(s): ShadowDashActivity: set touch listeners
DEBUG 0.21000(s): ShadowDashActivity: checkExpiration()
DEBUG 0.21200(s): ShadowDashActivity: initDashboards()
DEBUG 0.21300(s): ShadowDashActivity: addSavedDashboards()
DEBUG 0.21400(s): ShadowDashActivity: onCreate() DONE
DEBUG 0.21500(s): LoggerMonitor::onStart() called
DEBUG 0.21500(s): ShadowDashActivity: initializeWakeLock()
DEBUG 0.21900(s): LoggerMonitor::onResume() called
INFO 0.24600(s): Initializing GPS Manager
5/7/14 9:47:14 AM :Info: Initializing internal GPS
5/7/14 9:47:14 AM :Info: Internal GPS initialized
5/7/14 9:47:14 AM :Debug: ExtGPSManager.stop() ExternalGPS
INFO 0.46600(s): Time to read cached version of home_landscape.dash: 248.0
INFO 0.77600(s): Time to read cached version of home_portrait.dash: 309.0
5/7/14 9:47:14 AM :Debug: Typeface for 'Arial Normal' not found.
DEBUG 1.04000(s): ShadowDashActivity: addSavedDashboards() complete: 827
INFO 1.04600(s): Found FTDI Device 0
INFO 1.06100(s): Creating Bluetooth Interface to connect to: EFI Analytics 05: 00:12:6F:23:23:12
INFO 1.07100(s): Calling Connect
INFO 1.07500(s): Connecting Attempt started
5/7/14 9:47:14 AM :Debug: Got BT Socket
5/7/14 9:47:14 AM :Debug: About to connect Socket
5/7/14 9:47:15 AM :Debug: Socket connected
INFO 1.93100(s): Connected to :EFI Analytics 05
INFO 1.93200(s): Connected
INFO 1.94000(s): Starting StartRuntime1399470435796
DEBUG 1.94100(s): config is null, going to interrogate
DEBUG 1.94300(s): StartRuntime1399470435796 about to interrogate 1
INFO 1.94300(s): Searching for Controller
5/7/14 9:47:15 AM :Info: Comm Read Thread Change! Old Thread:null, new Thread:StartRuntime1399470435796
5/7/14 9:48:47 AM :Debug: ExtGPSManager.stop() ExternalGPS
INFO 93.98900(s): Stopped runtime reads
Shadow Dash MS 1.19 Started.
Start time: Wed May 07 09:49:30 EDT 2014
That looks like the file, but it says you are running version 1.19
I change it back to the same I have in my phone to see if that works but still the same problem I was running 1.24
did you find something that can find the problem?LT401Vette wrote:That looks like the file, but it says you are running version 1.19
I thought I was waiting on an app debug from 1.24?
At this point I don't really have anything to go on. As you see it is working fine on your other device. So I need to find out what is different on this one.
One thing that may be worth trying is to delete the .efiAnalytics dir from the sdcard.
Also, what version 3.3 firmware is it? I want to make sure it has the right ini. It does have internet access to get the right ini, yes?
I erased the .efiAnalytics from the tablet and replaced with a copy of my phone but still the same,the ini es the 3.30t and It do not search for it in the net like my phone,the phone search for it in the net and download it but the tablet do not do that.I dont know if I deleted the right file,is in /storage/emulated/0/.efiAnalytics is that the right one?LT401Vette wrote:I thought I was waiting on an app debug from 1.24?
I buy the 1.24 erased all the files and still the same problem.LT401Vette wrote:I thought I was waiting on an app debug from 1.24?
Code: Select all
INFO 0.00000(s):
DEBUG 0.01200(s): Starting ShadowDash Service
5/12/14 11:58:02 AM :Debug: Command Non-VolatileBytes for F resolved to: x46 F
5/12/14 11:58:02 AM :Debug: Command Non-VolatileBytes for I resolved to: x49 I
5/12/14 11:58:02 AM :Debug: Command Non-VolatileBytes for f resolved to: x66 f
DEBUG 0.05800(s): Installation Source: com.android.vending, com.efiAnalytics.shadowdash
DEBUG 0.06200(s): Installation source: com.android.vending
INFO 0.06200(s): Licensing managed by google
INFO 0.12900(s): License Validated by Google
DEBUG 0.13000(s): Cached EFI Activation of Google license validated.
DEBUG 0.13200(s): ShadowDashActivity::onCreate called
5/12/14 11:58:02 AM :Debug: Get LocationProvider
5/12/14 11:58:02 AM :Debug: locationProvider: gps
5/12/14 11:58:02 AM :Debug: bestProviderName: gps
5/12/14 11:58:02 AM :Info: GPSManager initialized
DEBUG 0.17700(s): ShadowDashActivity: viewSwitcher created
DEBUG 0.22200(s): ShadowDashActivity:: setContent
DEBUG 0.22200(s): ShadowDashActivity:: added home
DEBUG 0.22300(s): ShadowDashActivity:: got references
DEBUG 0.27500(s): ShadowDashActivity:: created home dash
DEBUG 0.27600(s): ShadowDashActivity:: set Home dash
DEBUG 0.27700(s): ShadowDashActivity: created buttons
DEBUG 0.27700(s): ShadowDashActivity: readPrefs ??
DEBUG 0.27700(s): ShadowDashActivity: checkBtInitialization
DEBUG 0.27800(s): ShadowDashActivity: updateDeviceInfoDisplay()
DEBUG 0.28200(s): ShadowDashActivity: queued logs for upload
DEBUG 0.28400(s): ShadowDashActivity: gesture stuff
DEBUG 0.28600(s): ShadowDashActivity: set touch listeners
DEBUG 0.28800(s): ShadowDashActivity: checkExpiration()
DEBUG 0.29100(s): ShadowDashActivity: initDashboards()
DEBUG 0.29100(s): ShadowDashActivity: addSavedDashboards()
DEBUG 0.29300(s): ShadowDashActivity: onCreate() DONE
DEBUG 0.29900(s): LoggerMonitor::onStart() called
DEBUG 0.30100(s): ShadowDashActivity: initializeWakeLock()
DEBUG 0.30100(s): LoggerMonitor::onResume() called
INFO 0.32400(s): Initializing GPS Manager
5/12/14 11:58:03 AM :Info: Initializing internal GPS
5/12/14 11:58:03 AM :Info: Internal GPS initialized
5/12/14 11:58:03 AM :Debug: ExtGPSManager.stop() ExternalGPS
INFO 0.38100(s): Did not load cached version of home_landscape.dash, error reading cache file.invalid primitive conversion
INFO 1.12600(s): Found FTDI Device 0
INFO 1.13500(s): No Prolific devices found.
INFO 2.96400(s): Time to save cached version of home_landscape.dash: 82.0
DEBUG 2.96500(s): 2581.0ms. to load /storage/emulated/0/Shadow Dash MS/home_landscape.dash
INFO 2.99300(s): Did not load cached version of home_portrait.dash, error reading cache file.invalid primitive conversion
INFO 5.16000(s): Time to save cached version of home_portrait.dash: 42.0
DEBUG 5.16100(s): 2166.0ms. to load /storage/emulated/0/Shadow Dash MS/home_portrait.dash
DEBUG 5.23400(s): ShadowDashActivity: addSavedDashboards() complete: 4943
5/12/14 11:58:08 AM :Debug: Typeface for 'Arial Normal' not found.
DEBUG 8.11100(s): LoggerMonitor::onPause() called
INFO 8.23800(s): Found FTDI Device 0
INFO 8.24400(s): No Prolific devices found.
INFO 9.95800(s): Creating Bluetooth Interface to connect to: EFI Analytics 05: 00:12:6F:23:23:12
DEBUG 9.96800(s): LoggerMonitor::onResume() called
5/12/14 11:58:12 AM :Debug: ExtGPSManager.stop() ExternalGPS
INFO 10.80000(s): Found FTDI Device 0
INFO 10.80200(s): No Prolific devices found.
INFO 10.80400(s): Creating Bluetooth Interface to connect to: EFI Analytics 05: 00:12:6F:23:23:12
INFO 10.80600(s): Connection closing: EFI Analytics 05
INFO 12.29800(s): Calling Connect
INFO 12.30000(s): Connecting Attempt started
5/12/14 11:58:15 AM :Debug: Got BT Socket
5/12/14 11:58:15 AM :Debug: About to connect Socket
5/12/14 11:58:16 AM :Debug: Socket connected
INFO 13.72700(s): Connected to :EFI Analytics 05
INFO 13.73700(s): Connected
INFO 13.75500(s): Starting StartRuntime1399910296556
DEBUG 13.75800(s): config is null, going to interrogate
DEBUG 13.75900(s): StartRuntime1399910296556 about to interrogate 1
INFO 13.76000(s): Searching for Controller
5/12/14 11:58:16 AM :Info: Comm Read Thread Change! Old Thread:null, new Thread:StartRuntime1399910296556
Shadow Dash MS 1.24 Started.
Start time: Mon May 12 12:02:33 EDT 2014
Please I need this to work thanks
Interesting, it works with one and not the other.
In you log, it does appear to be connecting to the BT, but not talking to the controller. That is the pop message you are seeing I take it.
Perhaps see if you can connect to it with Shadow Logger:
http://tunerstudio.com/downloads2/Shado ... _v1.21.apk
Or install Blueterm and see if you can connect and get a response to a S
I installed shadow logger but it do the same,is something to do with the tablet itself ?LT401Vette wrote:Interesting, it works with one and not the other.
