Custom dash questions
How can I export a custom dash from ts to shadowdash?
Re: Custom dash questions
Also I have diferent models of ms its there a way to have diferent gauges profiles depending on what ms project I am using? I for somemreson ifmamchwge a gauges let say rpm for ms2 but I conect to my ms3 and I want to see in that gauge the vss why can I have both right I just switch the gauge but a different profile would be nice
http://tunerstudio.com/index.php/manual ... ow-dash-msjuansh2385 wrote:How can I export a custom dash from ts to shadowdash?
You can have different dashboards for your MS2 & MS3 on the dash boards for page 2 & 3.juansh2385 wrote:Also I have diferent models of ms its there a way to have diferent gauges profiles depending on what ms project I am using? I for somemreson ifmamchwge a gauges let say rpm for ms2 but I conect to my ms3 and I want to see in that gauge the vss why can I have both right I just switch the gauge but a different profile would be nice
If you have already connected to both of them, then you will find the dirs:
/Shadow Dash MS/MS3/
and
/Shadow Dash MS/MS2_Extra/
Under each of those you will see a dashboards dir. You can put your MS2 and MS3 specific in those dirs.
I did that but did not work. I attach the dash that I am trying to use I replace the dashboard_0_landscape.dash file for the one attached but it is no change is showing in my tablet. galaxy tab 3 7 inch if it mater running beta.
Juan
Juan
Any pointers? I have try this without success not sure what more can i try. The dash works fine in tunerstudio but does not load in shadow dash
Phil is the dash posted compatible with shadow dash?
Sorry for the delayed response, I have been out of the office.
I just tried your dash, it seems to work fine except the MPH gauge is not assigned to any OutputChannel. That just made it load with a cross through it though.
One thing to try, make sure Shadow Dash has completely closed after changing the dashboard. Swipe it out from the recent apps menu.
as this is an MS3 dash, it should be in the dir:
/Shadow Dash MS/MS3/dashboard/dashboard_0_landscape.dash
could you do some more explaining about making custom dash board in tunerstudio
i mad one and it works if i keep the phone upright
but placing it horizontal makes it revert back to the old screen
for each customizable dash there are 2 files dashboard_X_landscape.dash and dashboard_X_portrait.dash
the landscape dash is for when the Phone is sideways, the portrait is for upright dashboards.
i renamed the same dash to landscape
removed all the screens from my ms2 dashboard
and still get the same result upright it,s there
sideways old screen as above
Perhaps make sure Shadow Dash is fully swiped closed.
i think i found why it does not work right away
even if you have removed the dashes
go out of shadow dash and reconnect it still shows the old dash
if i restart my phone then start shadowdash it will pick up the new dash
i guess the dash stays in some memorybank and is not cleared when you go out of shadowdash
unless you restart the phone or atleast on mine
galaxy S4
galaxy S4
Yep, you can swipe it closed from the task list, then it will close all the way and load the dash.if i restart my phone then start shadowdash it will pick up the new dash
