shadow dash BT connection
MS3X running current release 1.3.1
when connecting to via BT:
connected to efi analytics05
loading config ms3
unable to get appropriate project:newer version of this application required to load ecu def
when i go to the playstore to update it does not give me the option to update the app, not sure if this updates by itself or not, i dont recall updating recently and its the first time i have used it this year.
loading config ms3
Re: shadow dash BT connection
What version Shadow Dash do you have?
1.25 is the current stable release, that does support all the current firmwares.
I'm not sure why Google wouldn't be offering it if you don't have the latest.
Hmm, it may be your hardware is filtered for the current release. It should still be supporting back to Android 2.2.
What sort of device is it?
Google nexus 7, first generation.
That should be fine for sure.
What version does it say you have?
Shadow dash version 1.00.1 is what it says in app info.
I will say this is the first time this year I have tried to use it.
Yes. That is too old to run any of the new firmwares. If you bought it from Google Play, there should be an update avvailable. If you installed it from a download, then you will need to download the update from the TunerStudioAppDebug download site.
1.0 didn't have auto update in it yet.
thanks Phil,
I updated it and all worked fine. i was getting somewhat frequent "unfortunately app stopped working" while using 1.2.1 but seems i have not had that problem yet since update. So will it now prompt me to update??
YepSo will it now prompt me to update??
Thanks Phil, love this product. Nice work
