kindle
Re: kindle
It should work fine.
What version Android is it on?
Does it have bluetooth? (Some older ones I think did not.) If no Bluetooth, you may need to use a WiFi to RS232 adapter for connectivity.
If you don't have Play store access, you will need to download it from:
http://tunerstudio.com/index.php/downloads
There are instructions on side loading a downloaded app here:
http://tunerstudio.com/index.php/shadowdashmsmenu
Re: kindle
It does have blue tooth and as far as i can tell os system is 4.2.2
Re: kindle
It should be fine then.
You can download and try it, SD will connect for 3 minutes at a time when unregistered.
http://www.tunerstudio.com/index.php/downloads
Re: kindle
Got the blue tooth side loaded shadow dash on to the kindle works great thank you very much!
