wierd shadowdash thing
K ...I am a occasional racer. last time was in april. The shadowdash app gave me problems with registration . An email to efianalytics fixed it . I set up an autox with me,my son, and my dad today (frickin awesome)and attempted to use shadowdash again and again it screwed with me by saying that there was a registration problem. I got home and tried to replicate it and could not . What gives? Its gotta be a googleplay thing but I have bought this app twice through google play an had registrations sent 2 times through EFI analytics so I feel I should be more than covered . Why do I keep getting hosed when I decide to log with shadowdash? This is with a samsung S4 running the latest software. When the malfunction occurs there is no wifi. once wifi is available then the problem appears to disappear,
Ricky-
MS3&MS3X v.3.0 PCB
LS3/LSA card MAF sensor
97 Mazda MX5
MS3 2002 vvt motor
.60 trim T4 Turbo at 15 PSI
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
Re: wierd shadowdash thing
Are you currently running on the EFI Analytics License or Google Play.
Google Licensing seems to time out if you haven't been connected to a network while running thee app in too long. I have come up with a way around this.
I intended to be running the app on the efi analytics license . I reregistered it back in april when a support tech emailed me a registration and didn't use it for a couple months then fired it up to use it at an autox on fathersday and dang thing did it again. How do I ensure google play has nothing to do with the app in the future?
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
Uninstall it from google play, then download the one from tunerstudio.com and install that.How do I ensure google play has nothing to do with the app in the future?
That one will use the EFI Analytics registration.
It sounds like I better get that work around for Google play out there.
That's just the thing Phil. When this happened in April....I uninstalled the app from the phone, I downloaded and installed the app from efi analytics and then put it in the registration that you guys provided and it worked then the next time I tried to use it then I got this again. Ill try it again as you say but Ive only had the phone 6 months and ive only installed the app from your site not googleplay.
I had installed it from googleplay on my tablet way back last year and kept having troubles like this so I haven't messed with googleplay since then. Whatever is happening is a mystery to me .
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
Is it a big gap between running it? It shouldn't matter though.
couple months sometimes. I have not tried it since fathers day and have not done anything to the app since then so If you like I can try and see if I can reproduce it again.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
I just went out and checked it and it connected , logged into shadowtuner .com and started logging like it should. I ran the log for 2 -3 minutes until I ended the log and the app. When it does it ....it connects to the MS then comes up with the message and offers 2 options. 1 is to register it and the other is to close the app. Each time this has happened has been at a racetrack or autox where I had no wifi availability if that means anything. This last time it acted up until I got home and parked in the garage which is in range of my wifi and it worked fine as it did just a few minutes ago.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
That sure sounds like it isn't using the cached activation for some reason. I'll need to look into that.
