Page 2 of 2
Re: Shadow Dash 101 (installation)
PostPosted: Mon Jan 01, 2018 3:25 pm
by 1jzTaco
how do i configure the bluetooth adapter? im having same issue im using MS3
PostPosted: Tue Jan 02, 2018 7:42 am
by Brian H EFI
lunch_Programmer.bat.txt
(125 Bytes) Downloaded 3 times
Please download and install the programming utility from the link below.
http://efianalytics.com/TunerStudio/sup ... _setup.exe
If you do not have a Java JRE installed on your PC then you will need to use a batch file to launch the utility program.
Once you install the program connect your Bluetooth adapter to your PC using a USB to serial cable or a true DB9 port, now make sure that the little switch on the top is in the position closest to the DB9 connector then power on the BT adapter.
To re-program the Bluetooth adapter start the program (if you do not have a JRE installed you will need to go to the install directory and place the attached batch file included above to launch the program. Once you have move the batch file into the install directory double click the batch file and the utility application should start.) and click ok with simple mode selected. Now select what type of MegaSquirt ECU you have from the drop down menu. Once you have selected your ECU type go ahead and click start the program will now detect the Bluetooth adapter and reprogram the settings.
The install path for the utility app is below. If you need the batch file you will need to place it in the install directory then rename it and remove the .txt from the end of the name.
C:\Program Files (x86)\EFIAnalytics\WirelessUtility
After connecting to the Bluetooth adapter from the PC make sure that you change the switch position back to the position closest to the antenna before you try and make a connection with your ECU.
