Shadow dash problems
mazdaspeed
Post by mazdaspeed »
I am having 2 issues with shadow dash first is if Bluetooth is enabled before opening shadow dash i get this error:
The application Shadow Dash MS (process com.efiAnalytics.shadowdash) has stopped unexpectedly. please try again
then my only option is to force close the app..
next if i turn bluetooth off i can get into the app then begin to connect to the megasquirt ecu then the following comes up for 1/2 a second: Unable to get appropriate project: Problem loading /mnt/sdcard/.efiAnalytics/config/settinggroups.xml, error message: /mnt/sdcard/.efianalytics/config/settingsGroups.xml(no such file or directory) Check log file for more details.
Can anyone help me get this going shadow logger and msdroid are seeming to work fine
thanks
LT401Vette
Re: Shadow dash problems
Post by LT401Vette »
It sounds like it is crashing before all the files are copied to the working space.
What kind of tablet is it?
What OS version is on the tablet?
Can you post the appDebug.txt file?
mazdaspeed
No brand just a cheap unit
Android 2.2.2
LT401Vette
Many of the cheap knock no name tablets have many driver issues, especially with Bluetooth and GPS.
Also, the 2.2.2 may be the problem. Currently, we are only testing back to 2.3.
It would be interesting to try Shadow Logger and see if that works. It should still work with 2.2, but will still require the devices bluetooth to be working properly.
http://tunerstudio.com/index.php/shadowloggerms
Lancianut69
Post by Lancianut69 »
Was there any resolution to this problem?
Reason for asking is that I have been using shadowdash on a commtiva N700 for the last couple of years without any problems whatsoever. Just finishing an install on a customer car, and setting up exactly the same system, and I'm getting the same issue, ie once file downloaded and started, I get the error message and force quit. Logger software boots up no problem - help!
Cheers
Darren
