logging with shadow dash
just realised shadow dash does not log anywhere near as many fields as logging through tuner studio, is this normal?
Re: logging with shadow dash
Nope, it should log exactly the same fields, plus any device sensors.
What firmware are you running?
its ms3 pre1.4a7 , some of the dash indicators are playing funny games to, one thing dawned on me do i need to drop the correct ini file in to shadow dash??
That explains it... The ini for that wasn't on the server yet.
I just added it, so now it should be good as long as you have internet access when you connect the 1st time.
