Shadow Dash GPS Speed
I can't seem to get the GPS Speed to work. MSDroid GPS Speed is working fine so I know its not a GPS issue. This is on a Samsung Galaxy Tab 2 7.0. Any thoughts?
1966 Mustang Fastback
302 HO,Trick Flow TW 170 heads, Headers/dumps, MS3
Re: Shadow Dash GPS Speed
Is the Speed gauge set to the Controllers speed or the GPS speed?
You can change it by doing a long touch on the gauge.
I set it to GPS speed. But, I noticed that nothing I did is saving. The gauges I set up are saving but when I connect to the ECU, they don't work. I have to go through the process like I am setting them up for the first time. Under the file tab, log is the only option I can select. Save and load tune are grayed out. Is there a save I am missing to make the gauges work when it reconnects? I have MSDroid on the same tablet and everything works on it so it isn't the tablet.
Which dashboard are you setting it on? The Last dash always loads the default gauges for your firmware when you connect, only the 1st 3 dashboards save.
Pretty sure I am using the default dashboard but not sure. I am out of town and don't have that tablet with me.
