I'm using an Innovate LC-2 Controller and gauge.
It's my understanding that when I KEYON, the sensor is heated and the controller goes through some form of startup and will not report an accurate reading until the sensor heats up. It seems to take ~20 seconds for the gauge to display the actual AFR.
If my engine reaches operating temperature (~180), then KEYOFF, and immediately KEYON, it takes another ~15 seconds for the Gauge and TunerStudio to report the actual AFR.
So, from my perspective, the sensor should already be at a sufficient operating temperature. Which leaves me to believe that the controller is taking ~15 seconds to "boot" up, which seems like an eternity.
When I called Innovate Tech Support and articulated this observation, they said that this is the expected behavior. I attempted to glean out more details, but the Tech could or would not provide any details and audibly became agitated, so I thanked them and moved on.
If anyone can help me understand "WHY" this delay exists, I sure would appreciate it.
I'm new to MS and while it's Cold here in Texas, I'd like to work on my WUE.
Thanks in advance,
-D
P.S. If it seems that I'm splitting hairs and/or this delay is insignificant, please shoot straight and tell me to drop the ball. I will let it go.
LC-2 Controller Delay in restart
1992 Mustang Conv,
363" Man-o-War (8.2"Deck), Dart Pro-1,
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
Innovate DLG-1 (dual WB O2)
Ignition LS2 coil on plug (Crank trigger+ Explorer cam sensor)
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
Re: LC-2 Controller Delay in restart
I would not expect any wideband O2 controller to report accurate AFR data immediately after power on no matter when it was shut down. A 15 second delay seems reasonable to me.
based on Bosch recommendation the ramp up rate for the heater voltage must be maxiumum 0.4V/s.
If the heater control meet the sensor manufacturer requirements, we need at least min. 10s to arrive to approx. 90 -95% heater power for fastest heat up stage, but this does not mean the sensor is at operating temperature yet.
I agree with Jean and the 15s is realistic.
Attached the corresponding part from the sensor datasheet.
Zoltan
Zoltan
Alfa Romeo 75 2.0, Supercharged by Eaton M45, MS3
Great information gents.
Educational and greatly appreciated.
1992 Mustang Conv,
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
