Dear Phil,
Sorry to bother you again. I switched to the latest pre-1.4 rc 16, because I struggled with my CL boost tuning quite a lot. Now, the trick with copying MyCurrent.msq to SD doesn't work. No connection to ms as usual. Could you upload an update to SD that would solve the issue?
Thanks beforehand.
Shadow Dash and egt reading.
Re: Shadow Dash and egt reading.
Yep... Didn't have the ini for that firmware on the server yet... It is there now and should update the next time you try to connect and have internet access.
