Installed shadow dash from efianalytics v1.27. On new Samsung galaxy tab 4 Android OS version 4.4,2. Cannot access main dash menu. Won't display at bottom of screen seems to be cut off. Just the entire dash is displayed. All tablets screen settings look to be set normally, no zoom, ect. Does connect to vehicle.
Same concern occurs on galaxy note 4. But displays properly on HTC one m7 android
shadow dash won't display button for main menu galaxy tab 4
Re: shadow dash won't display button for main menu galaxy ta
Shadow Dash is still using the older 2.3 menus. It seems on the latest Samsung phones they have started hiding those, but there is usually a trick to making them show.
On the S5 if you long touch the task manager button, the menus come up.
The next release of Shadow Dash will have the newer style Action Bar.
Thank you Phil, worked fine on the Galaxy Tab 4 8.0.
As always great response and support.
thanks
Tim
thanks
Tim
