Vehicle Speed in SD
kizzoalfa
Vehicle Speed in SD
Post by kizzoalfa »
does it possible that I get speed displayed in MPH all the times? I tried to change to KPH in references, but no change. It is in 1.32
Thanks,
Zoltan
Alfa Romeo 75 2.0, Supercharged by Eaton M45, MS3
LT401Vette
Re: Vehicle Speed in SD
Post by LT401Vette »
GPS Speed or firmware speed?
Which firmware are you using?
kizzoalfa
Post by kizzoalfa »
Hi Phil,
it is vehicle speed for example vss1. I am using MS3 1.3.2.and SD 1.32.
Thanks,
Zoltan
LT401Vette
It is possible.
I'll have to look at this, I thought it was already addressed. But for that firmware the scaling was changed to be managed based on a settings in your msq. But it is a PCVariable, so it is not on your controller. SD would need to change it itself. That logic may have gotten lost.
If you copy your CurrentTune.msq from your PC over to the SD MS3 folder, it should then load the needed values from the CurrentTune.msq
kizzoalfa
Post by kizzoalfa »
LT401Vette wrote:It is possible.
Hi, I copied, but no change. I created a custom ini where speed = vss1 * 1.61 and I display speed in SD. This works.
Zoltan
