Is it possible to toggle an output via a button/icon on the dash? E.g. switching lights, various solenoids etc. Ideally I would like full control via tablet instead of having the odd mechanical switch around the console.
Thanks!
Shadowdash Buttons?
Re: Shadowdash Buttons?
This would require changes to the firmware as well.
Oh really? I was hoping to assign an output such as Nitrous or fan to toggle a relay based on an input condition (hi/low) that could be overridden or simulated by touching a button on the shadowdash instead of having a physical wired switch. I thought with all the I/O capability of the MS3X this would have been quite easy
How did you think it was going to work?Mrstoks wrote:I thought with all the I/O capability of the MS3X this would have been quite easy
Well I don't know exactly, just seems like the MS3X has a heap of I/O functionality with dozens of outputs that can be switched based on conditions of inputs.
So I thought that perhaps some of these outputs could be linked to a button/icon on a tablet with shadowdash that could function as an input or simulate/override an input.
My experience is with automation PLC's, but I kind of see the Megasquirt as an automotive PLC. I guess I'm used to being able to force I/O as needed for diagnostics etc, so didn't see it being out of the question to do what I want it to do.
I notice that datalogging can be toggled On/Off via the ShadowDash, I realise this is not an 'input' as such, but would be handy to have the same functionality to switch various relays etc via the same 'dash'
Yes, but there still has to be programming to make that happen.
