Shadow dash was working fine till I updated my MS firmware to ms2extra-pre3.4.2beta2. After that the main page said not connected but in the drop down menu I could click on disconnect so it was connecting to the Bluetooth fine.
Today I loaded ms2extra-release-3.4.2 to see it it would work and I have the same problem. Dose the same on 2 different devices.
On one of them I deleted Shadow dash and reinstalled it to see if that would help and I had the same problem.
What do I need to do to fix this?
Shadow Dash V1.32 stopped working
89,88,87 Conquest TSI
1971 Jeep CJ5
MS2-V3.57 with map daddy, software 3.4.2 with EDIS on a Mitsubishi 2.6l turbo.
using Tuner Studio V3.0.28 / megalog viewer V4.1.17 and Shadow Dash V1.5.02
1971 Jeep CJ5
Re: Shadow Dash V1.32 stopped working
Both of those firmwares use the same ini and it wasn't on the server...
It is there now, should work as long as you have an internet connection the 1st time you connect to the MegaSquirt.
Thank you.
All is working again.
1971 Jeep CJ5
1971 Jeep CJ5
