Shadowdash won't run
Neno
Post by Neno »
I'm using shadowdash for a long time now and it has been working perfectly on my phone. Now I've installed a 2DIN android radio in my car and I'm having problems running shadowdash. I've managed to install the apk but as soon as I start the program I can see the application for a second and than it crashes.
Is there any way to identify what is causing the crash?
The radio is running Android 4.4.4 Kitkat.
This is the radio I have (https://www.carjoying.com/eu-warehouse/ ... ersal.html)
Thanks!
Best regards,
Nenad
...only 0.5bar... :)
LT401Vette
Re: Shadowdash won't run
Post by LT401Vette »
Is there a Shadow Dash folder created and an appDebug.txt in it.
That often doesn't have a great deal of debug info in it, but at least we can see how far it is getting.
Neno
Post by Neno »
Here is the file...
LT401Vette
It looks like it is getting quite far, on the 1st 2 starts it looks like it fully started? It loaded dashboards and all.
It looks like you are using 1.31, so 1st thing I would try is upgrade to 1.32.
http://www.tunerstudio.com/index.php/downloads
Neno
Post by Neno »
Once it shows the dashboard it crashes. This is happening every time i start the program.
Today I've downloaded the last version and installed it. I get the same behavior.
I've attached new appdebug.txt.
Thanks!
LT401Vette
That is still showing it as 1.31?
Something I noticed in the file, there is no Bluetooth initialization. I have a feeling it is crashing when it tries to initialize the Bluetooth.
Try connecting to your MS with Blueterm, see if that causes a crash.
red-racing
Post by red-racing »
Did you make it run? I have the same problems
LT401Vette
red-racing wrote:Did you make it run? I have the same problems
Make sure you have a paired BT device.
Neno
Post by Neno »
Not yet. I tried connecting with Blueterm and i got connection. But now i have no idea what to write on the blue screen.
I will have some spare time over the weekend so I'll look into it in a bit more details.
Sent from my SM-G900F using Tapatalk
Neno
Post by Neno »
The device is paired.
