I have configured my MS2 with oiltemp and oil pressure. I used the custom channel i the new tunerstudio to make it work.
But how do I transfer this guages to shadowdash?
I have read something about import the dashboard.
Will it come a custom channel function in shadowdash as well?
\\ tom andre
display Oiltemp/pressure in shadowdash
Re: display Oiltemp/pressure in shadowdash
If you copy the custom.ini from your TunerStudio Project, to your Shadow Dash Project, then you will have your new gauge on the long click menu:
Copy:
[YourPC]/[YourTunerStudioProject]/projectCfg/custom.ini
to
[YourAndroidDevice]/Shadow Dash MS/MS2_Extra/projectCfg/custom.ini
Then restart Shadow Dash.
You can move your TunerStudio Dashboards over to Shadow Dash too, but they must be saved with TS 2.6.x still. The 2.9.x dashboards aren't supported in SD yet.
http://www.tunerstudio.com/index.php/ma ... ow-dash-ms
Copy:
to
so I need only to move the custom.ini?
what about the inc file for the oil temp sensor?
if your new channel uses an inc file, then yes, you need to move that too.
put it in:
[YourAndroidDevice]/Shadow Dash MS/MS2_Extra/inc/
put it in:
