I'm using Shadow Dash MS v1.32 on a LG G4. When I go to the preferences and select Enable Automatic Logging the option below - Set Auto Logging Condition - stays disabled. It says the current condition is Manual.
How do enable this option and change this from manual to an RPM value?
thanks
Frank
Shadow Dash - Enable Automatic Logging
Re: Shadow Dash - Enable Automatic Logging
Is there anyone supporting this software?
Been a week and no response. Can someone else check and see if the same thing happens on their phone please.
thanks
thanks
I'm not sure How I missed this post...
The automatic logging condition should become enabled once you check "Enable Automatic Logging" above it. That appears to be a bug.
There is a new release coming very shortly, I'll get that resolved.
Awesome.
Thanks. Would it be available by Saturday? No pressure.
Since you're looking at that issue can I make a request... The "start log" button is very difficult to read. Would you consider changing the transparency so it shows better?
thanks Again.
thanks Again.
Have recently updated my android tablet , when I go into preferences > Enable Automatic Logging, the option to Set Auto Logging Condition remains shadowed and doesnt allow me to change from manual. I can still toggle Auto logging and change the logging condition on the old tablet which is running v1.6.06. New tablet is using v1.6.10. Are there any known issues with this version or other settings I need to fiddle ?
Try connecting to the MS, then enable Auto Logging.rallyrs wrote:Have recently updated my android tablet , when I go into preferences > Enable Automatic Logging, the option to Set Auto Logging Condition remains shadowed and doesnt allow me to change from manual. I can still toggle Auto logging and change the logging condition on the old tablet which is running v1.6.06. New tablet is using v1.6.10. Are there any known issues with this version or other settings I need to fiddle ?
