Shadow Dash not saving changes
Postby xanmanae86 » Mon Dec 12, 2016 5:47 am
I'm having an issue with shadowdash where my gauge limits are weird. Tach max is at 100 and my a/f histogram goes with a 0-100 range instead of 10-20. Now I can change them and it works, but it won't save the settings that I've changed. I also get an error that says unable to save dashboard please check log file, but I cannot find any info in any log about why it's unable to save.
xanmanae86
Re: Shadow Dash not saving changes
Postby LT401Vette » Tue Dec 13, 2016 7:16 am
what dashboards are you using?
Are they the ones that came with it, or TS 3 dashboards?
LT401Vette
Postby xanmanae86 » Tue Dec 13, 2016 10:48 am
I'm using one that I made with TS3. I've attached the dash that will not save changes.
dashboard_0_landscape.dash
(263.35 KiB) Downloaded 26 times
xanmanae86
Postby LT401Vette » Tue Dec 13, 2016 3:45 pm
That is likely the problem. There is still a compatibility issue with TS 3 dashboards.
We are working on that one now.
LT401Vette
Postby xanmanae86 » Wed Dec 14, 2016 11:03 am
Ah okay. How far back version wise do I need to go to make a dash that'll work?
xanmanae86
Postby LT401Vette » Wed Dec 14, 2016 2:14 pm
Use the 2.6 TunerStudio to edit dashboards.
http://www.efianalytics.com/TunerStudio ... dReleases/
Hopefully the new SD release will be soon.
LT401Vette
Postby VcrMiata » Sat Apr 29, 2017 9:29 pm
Is this still an Issue?
I want to modify my guage limits from an TS 3 dash (rpm) imported into shadowdash and due to the guage limits not being used I set them again in shadowdash but the changes are not being preserved.
I'm using shadowdash v1.5.02
VcrMiata
Postby LT401Vette » Mon May 01, 2017 7:56 am
1.5 should work fine with TS3 dashboards.
There is one known issue where Analog Moving Bar gauge is rendered as an Analog Bar Gauge.
This is fixed for the next release.
LT401Vette
Postby VcrMiata » Fri May 05, 2017 6:38 pm
Thanks Phil -
I wasn't clear above but I don't get an error while saving, the problem is the change I apply to gauge limits is not preserved if I exit and restart shadowdash.
I'm assuming the gauge settings will be preserved when closing the application as there isn't an explicit "save dashboard" option.
Maybe this is where I am going wrong, is there an explicit way to save a dashboard change?
I did try saving the tune, which completed successfully, but that doesn't change the gauge behaviour as described.
One other thing that may be related: I have 4 gauges that have boxes around them (the one I'm adjusting is not one of these) which implies there is a problem.
The 4 are calculated gauges associated with both fuel economy and power/torque. Maybe these are preventing the change from being saved?
The gauge I'm playing with is an Engine Speed gauge.
The gauge limits were set in TS3 but are not shown properly in shadow dash (seems to goes back to default). Changing in shadowdash again is also not preserved.
ProblemTS3Dash.dash
TS3 dash that cannot be saved in shadowdash
after changing gauge limits.
(364.33 KiB) Downloaded 13 times
Tony
VcrMiata
Postby LT401Vette » Sun May 07, 2017 7:42 am
They should be saved, I will look into it.
LT401Vette
Postby VcrMiata » Fri May 19, 2017 7:25 am
LT401Vette wrote:They should be saved, I will look into it.
Noticed this is also reported in a shadowdash review in the play store on 3/7/2017.
Is a fix scheduled?
Sent from my SM-T810 using Tapatalk
VcrMiata
Postby LT401Vette » Fri May 19, 2017 8:05 am
The fix is simple enough, but SD is going through some core changes that are holding up the next release.
LT401Vette
Postby VcrMiata » Fri May 19, 2017 8:02 pm
No worries and thanks for the update.
Now you have me peaked as to what the core changes will bring in the future... :D
VcrMiata
