I use ShadowDash sporadically to log data from my car, and in the past it's always worked well.
Yesterday and today I took logs on the drive to work, but they're empty! Yesterday I wasn't paying much attention and thought logging might have stopped for some reason, but today I specifically checked when I arrived at work and SD claimed it was still logging.
Any thoughts on why this might be happening?
ShadowDash empty log files
- Attachments
- 2018-02-21_06.10.27.msl
- (2.44 KiB) Downloaded 46 times
- 2018-02-22_06.06.49.msl
- (2.44 KiB) Downloaded 44 times
Eric Law
Re: ShadowDash empty log files
Thanks for reporting this issue. I am only seeing this in some cases when "Automatic Logging" or "Start Logging on Connect" is used to start the logs. The fix will be in the next release.
Workaround: Disable "Automatic Logging" and "Start Logging on Connect" in preferences and Manually Start datalogs
Thanks! I'm using both of those options (I know that doesn't really make sense but I think at one point in the past I had "start on connect" selected and it didn't always work so I turned on the other also). I'll turn them off and see if the issue is fixed.
Eric Law
FYI turning off those options and starting logging manually seems to have worked. Thanks!
Eric Law
