Getting Closed Loop To Work?
Postby CMac89 » Sat Sep 01, 2012 6:46 am
I've been trying to figure out how to get closed loop to operate correctly. The idle and AFR changes between 16.x AFR and 14.x in a nice, smooth, oscillation. It idles steadily in warmup mode, though.
Is this a common thing? If so, what do you guys recommend I do to fix it? It would be great to have it working correctly.
MS3Pro
1994 Thunderbird SC Fully Sequential SVO V6
Versafueler Peak and Hold Injector Driver
IGN-1A Coils
DIY Cherry Crank Sensor with Ford half-moon hall effect cam sensor
DIY 36-1 toothed crank wheel
1500hp goal!
CMac89
Re: Getting Closed Loop To Work?
Postby pit_celica » Sun Sep 02, 2012 5:04 am
Before trying CL idle or CL EGO, you need to be sure that your idle is quite stable at a constant PWM idle duty and the VE at idle shouldn't vary. Post a datalog and your msq file.
Sam
pit_celica
Return to Tuning
