Thanksgiving Holiday over here in the US. Most people sleeping off over eating, Over eating, or watching NFL?
Me? I am trying to figure out if a knock sensor will even WORK on our combination??
Gen I, Small Block Chevrolet V8, Solid Lifter, flat tappet camshaft?
Is this combination that is going to allow for a Modern Knock Sensors?
Am I looking for a head ache here?
Any one have success opinion or advice [ other than changing the cam !!! ]
Thanks TJM
Should I even TRY to use a knock sensor???
Re: Should I even TRY to use a knock sensor???
Which MS processor? I would try one if you have an MS3 and the knock module, otherwise don't bother.
Graduate of EFI University.
I have the knocksense unit but I had to turn the sensitivity down a lot or it would indicate knock almost continously. I read a lot of articles saying it's easier to detect knock by hooking it up to a headset.
elutionsdesign wrote:Which MS processor? I would try one if you have an MS3 and the knock module, otherwise don't bother.
Thanks!!!
MS3X/V3.0... I Never remember to tell you all that?? Backward .
I would invest in the thing if it had a potential value.
This is a pure race motor.. running E85 so I rationalize I won't have knock issue,
BUT... on the other had I DO want all that timing I can get.. which is a lot... especially when you have 300 gallon of 190 Proof to Blend UP!?!?
This was the motivation to Computerize.. all the power and no broken parts???? [ well.... fewer it is hoped?].
TJM
Merci Beaucoup!!!Yves wrote:I have the knocksense unit but I had to turn the sensitivity down a lot or it would indicate knock almost continously. I read a lot of articles saying it's easier to detect knock by hooking it up to a headset.
Practical to check onset limits on the Dyno, maybe?
The car runs 3,000 - 6,000 rpm... A LOT. It's a Road Racing platform...
TJM
On YouTube are several movies with the knock sensor recorded sound of detonation. Very interesting.TJM wrote:Merci Beaucoup!!!Yves wrote:I have the knocksense unit but I had to turn the sensitivity down a lot or it would indicate knock almost continously. I read a lot of articles saying it's easier to detect knock by hooking it up to a headset.
TJM
If this is for a dyno maybe you could invest in a pressure transducers system like the TFX unit. Lost of $ though.
If this is for a dyno maybe you could invest in a pressure transducers system like the TFX unit. Lost of $ though.[/quote]
Need to Google that!
No, I meant that we could look for the thresholds of Knock, when fine tuning on the DYNO.
The solution is a roller cam.. the most economical solution, other than living out there on the Edge of burning holes in pistons??
Next motor/rebuild for sure, though.
Bonsoir!
TJM
Bonsoir!
TJM
