Can someone check .msq what i am missing? I am getting RPM signal, spark and gas, i am guessing its probably something with spark timing?! Engine is almost stock
I am kinda new to this (tune, ms...) , i want to at least start the engine, before i go to the tuner...
Thanks you!
m50b26 won't fire but turns over (ms2)
Re: m50b26 won't fire but turns over (ms2)
You are guessing it is spark timing? Use a timing light to check timing for sure, on every cylinder if there is a problem when you try to start it. Use a simple (non dial-back) light, they seem to offer more reliable results.
okey, engine is firing but still no starting at all
maybe someone have base tune for m50 stock engines? Just to start the engine...
Thank you!
Thank you!
Did you check the spark timing, on all cylinders? Is that MSQ posted still current? Have you tried disabling the fuel pump/injectors and using starting-fluid to confirm this is *just* a fueling problem? Post the MSL of a starting attempt.
