Sample AFR Table and Spark Table?
herbie
Post by herbie »
Hello
I have about a week to go before my Ice Race season Start, and need to get my new setup running right.
This will be my 2nd installation of Megasquirt on a Chevette.
I do this by slapping a 700 Series TBI from an Iron Duke Fiero onto a 1" adapter plate where the carb used to be.
This year, I am boosting I'll be running from 30kpa to 160kpa in my tables.
Therefore I am looking for a sample spark table to go by.
Also looking for a sample AFR table to go by, so that I can crank up the VE Analyze Live.
RPM range from 500 to 6,000. (redline back to 5,800)
IN the past I would run it till the valves floated at 7,400 which has served me well for 5 years, but better dial it back.
Any starting point would be helpful. Car runs right now.
Thanks in advance
Herbie
1985 Chevy Chevette Ice Racer
700 Series TBI, Mitsubishi TD-03 Turbo, Direct Coil Control with Dizzy.
ol boy
Re: Sample AFR Table and Spark Table?
Post by ol boy »
here try this.
igntiontableboost.zip
I'm using this one from 700 rpm to 6500 rpm. Works for a 289 Ford V8.
herbie
Post by herbie »
Thank you kindly.
I will be giving this a go this weekend.
Woolmer
Post by Woolmer »
In the "Determining best power ratio without a dyno" thread it was mentioned that often optimum timing will be before detonation, depending on the engine.
kaleem
