Hello
I have about a week to go before my Ice Race season Start, and need to get my new setup running right.
This will be my 2nd installation of Megasquirt on a Chevette.
I do this by slapping a 700 Series TBI from an Iron Duke Fiero onto a 1" adapter plate where the carb used to be.
This year, I am boosting I'll be running from 30kpa to 160kpa in my tables.
Therefore I am looking for a sample spark table to go by.
Also looking for a sample AFR table to go by, so that I can crank up the VE Analyze Live.
RPM range from 500 to 6,000. (redline back to 5,800)
IN the past I would run it till the valves floated at 7,400 which has served me well for 5 years, but better dial it back.
Any starting point would be helpful. Car runs right now.
Thanks in advance
Herbie
Sample AFR Table and Spark Table?
1985 Chevy Chevette Ice Racer
700 Series TBI, Mitsubishi TD-03 Turbo, Direct Coil Control with Dizzy.
Re: Sample AFR Table and Spark Table?
here try this.
I'm using this one from 700 rpm to 6500 rpm. Works for a 289 Ford V8.
Thank you kindly.
I will be giving this a go this weekend.
In the "Determining best power ratio without a dyno" thread it was mentioned that often optimum timing will be before detonation, depending on the engine.
kaleem
