Hi.
I'm having a hard time figuring out this problem here
where it feels like missfires but doesn't show (to me) anything in the logs.
I've had real missfires and clearly shows because of the lean spikes.
Here: http://img.photobucket.com/albums/v163/ ... d55716.png
Using an msd and msd coil with plugs gapped to 0.025.
Thanks for looking. All opinions welcomed.
4th gear pull on the freeway and have to let off just when it starts to get good.
Stuttering but doesn't show in logs.
Ms2-3.4.2 v3.0 .
Turbo BMW m30b35.
Turbo BMW m30b35.
Re: Stuttering but doesn't show in logs.
My car misfires in that area too. I think it may be caused by knock, but I am not sure. Try adjusting the timing either way to see if it lessens in that area. I can see the misfire, its happening directly before the blue line. You can see it in the RPM and AFR.
Nissan Skyline R34 RB26DETT ran MS3/MS3X w/ factory Hitachi CAS (sold)
Nissan Silvia S14 RB25DE ITB/NA ran MS3/MS3X w/ factory Mitsubishi CAS (disassembled)
Datsun 240z RB25DE ITB/NA with MS3/MS3X
I'm retarded.
Just to close this thread it turned out the plugs were gapped at 0.030.
Guess even msd couldn't jump the gap. Gapped them to 0.025. Everything is good.
Knew it was going to be something stupid. Thanks for the help.
Ms2-3.4.2 v3.0 .
Turbo BMW m30b35.
Turbo BMW m30b35.
