Dead time measured, Delphi 95 lb/hr low z
I finally have the chance to give something back to this board. I used my MS3 and Tunerstudio together with a VersaFueler and my injector flow bench to measure injector dead time for Delphi's 95 lb/hr low impedance injector. I followed the lead of this youtube video http://www.youtube.com/watch?v=lJgi8l-2XG4. Next I will be testing Lucas 120 lb/hr low impedance.
Here is a pic of the test setup and an Excel screen shot showing the raw data and calculated dead times. If you'd like me to measure your injectors, send me a PM with your contact details.
Jeff
Jeff
Re: Dead time measured, Delphi 95 lb/hr low z
That is a freaking NICE setup! I am soooo jealous!
Thanks! This 4th order eq gives a reasonable curve fit:
y = 0.0002490398117·x4 - 0.01482719588·x3 + 0.3239904858·x2 - 3.163577576·x + 12.41638622
The 13.2 volt dead time is 0.57 ms.
Jeff
Jeff
would the 120# be the one trickflow sell as pn. 89120. if so im very interested. by trial and error i come up with around .65ms. voltage slope is way off though.
Can't you cheat it by switching from 2 squirts to 4 squirts and watch the Idle AFR? or some such...
I've never seen Trickflow injectors. Mine are made by Lucas.ashford wrote:would the 120# be the one trickflow sell as pn. 89120. if so im very interested. by trial and error i come up with around .65ms. voltage slope is way off though.
Jeff
looks to be the same unit9secz wrote:I've never seen Trickflow injectors. Mine are made by Lucas.ashford wrote:would the 120# be the one trickflow sell as pn. 89120. if so im very interested. by trial and error i come up with around .65ms. voltage slope is way off though.
Jeff
Here is the raw data and calculated dead time versus voltage for Lucas 120s:
Good curve fit eq:
y = 0.0001912278744 x4 - 0.01164420921 x3 + 0.2580019471 x2 - 2.556672106 x + 10.57121078
13.2 volt dead time is 0.80 ms.
BTW, don't nag about significant digits on the curve fit! It's just a copy paste from the algorithm.
Jeff
Good curve fit eq:
Jeff
thats really nice of you to do, thanks. btw use the data not the chart? i guestimater about a .7 dead time on my car using 2-4 squirts.
