I´m about to go on the dyno , so just wanted to make sure everything was ok.
Car is a bmw m20b20 with added turbocharger. Engine is completely stock apart from bigger injectors. Running 12 psi and so far no knock has been detected.
( MS2 extra in shape of MSPNP Generation 1 from DIY running current firmware)
I´m actually quite surprised the d*** thing hasn´t exploded yet. But it´s running like charm. A good wideband can get you a long way it seems
Anyway let me know if anything looks odd
/Per
Am I missing something
Re: Am I missing something
your fuel ve table only goes to 150 on the load, I suggest you increase to 50kpa over your normal boost level atleast, say 250kpa
Your datalog already shows you are going up to 180+kpa as well
Also I suggest a TPS and how big is the turbo?
MS2extra
Mass Air Flow fuel and spark
Miata 1.6 turbo
TechSalvager is banned for ignoring admin warnings not to link to his childish videos.
Miata 1.6 turbo
Thanks for the reply
I completely forgot about the Kpa scale thanks for the reminder
The turbo is a Garrett GT 2860 Rs ball bearing with a built in wastegate
Compressor turbine is 60 mm and exhaust turbine is 54 mm
A/R is 0.86
I´ve been thinking about adding a real TPS aswell , since i´ve had some trouble with the Accel Enrich. It´s kinda hard to make it cooperate with map only.
/per
A/R is 0.86
/per
My friend has a 2.7l m20 e30 with a GT2876R. With a TPS its a lot better.
Also I think the AFR target table takes a lot of fuel out, when your outside of boost. to much imo.
MS2extra
Miata 1.6 turbo
Miata 1.6 turbo
I´ll give it a go , been having a bit of lean surge in those areas.. Will try to add some fuel.
2.7 is a great engine. Is he using the stock head or the 885 head ?
2.7l bottom end, 2.5l head, forged supra rods, supra pistons.
MS2extra
Miata 1.6 turbo
Miata 1.6 turbo
