Re: Ign signal, tps, nightmare. Base map would be great!
Posted: Fri May 04, 2012 8:15 am
yes
Support and discussion forum for Megasquirt 1, 2, 3, Microsquirt/module, DIYPNP, MSPNP2, MS3-Pro
https://www.msextra.com/forums/
PM me your email and I'll send you a starter fuel tableblack 89turbo wrote:yes
Screen shot?billr wrote:Referring to "Tune1.msq" posted 5/3/2012:
To the right of "BANK 1 Dead time @13.2V(ms)" I see a data-box with ".752" in it.
Sounds like your req fuel is way too small or the problems in VE table made you have to run such a large valueblack 89turbo wrote:.
which outputs are you using? MS3X or standard?black 89turbo wrote:No go. I uploaded the table peter sent, set the dead time to .8. I also tried to up the PWM current all the way to 60 and still nothing. Take the dead time and put 7.0 in fires up without a hesitation.
Weird, very weird.billr wrote:Here it is, also the .msq Maybe it's a difference in the TS I'm using?
Standard/main board. Not getting into the ms3x portion yet. lol rookie at msPeter Florance wrote:which outputs are you using? MS3X or standard?black 89turbo wrote:No go. I uploaded the table peter sent, set the dead time to .8. I also tried to up the PWM current all the way to 60 and still nothing. Take the dead time and put 7.0 in fires up without a hesitation.
edit: I wonder if these are really high z injectors or there are ballast resistors installed.black 89turbo wrote:Standard/main board. Not getting into the ms3x portion yet. lol rookie at msPeter Florance wrote:which outputs are you using? MS3X or standard?black 89turbo wrote:No go. I uploaded the table peter sent, set the dead time to .8. I also tried to up the PWM current all the way to 60 and still nothing. Take the dead time and put 7.0 in fires up without a hesitation.
They ALL have 2.8ish give or take .1. I ohm them all out.billr wrote:Make it simple for me, forget about the injectors P/Ns and top colors; how many ohms of resistance on one?
My 4G63 has ballast resistorsblack 89turbo wrote:They ALL have 2.8ish give or take .1. I ohm them all out.billr wrote:Make it simple for me, forget about the injectors P/Ns and top colors; how many ohms of resistance on one?
Oem haress, ecu & resistor box?Peter Florance wrote:My 4G63 has ballast resistorsblack 89turbo wrote:They ALL have 2.8ish give or take .1. I ohm them all out.billr wrote:Make it simple for me, forget about the injectors P/Ns and top colors; how many ohms of resistance on one?
Hmm, maybe put a resistor box in? I never used a resistor box using these injectors on AEM, Microwreck or helltech all 4 cars ran for year/years before either upgradding injectors ect. You have the same injectors correct? Your running MS2? Do you have a wiring diagram of the resistor pack put into play?Peter Florance wrote:OEM harness, resistors and MSblack 89turbo wrote:
No you don't need one; my question is whether the ballast resistors are still in your harness.black 89turbo wrote:Hmm, maybe put a resistor box in? I never used a resistor box using these injectors on AEM, Microwreck or helltech all 4 cars ran for year/years before either upgradding injectors ect. You have the same injectors correct? Your running MS2? Do you have a wiring diagram of the resistor pack put into play?Peter Florance wrote:OEM harness, resistors and MSblack 89turbo wrote:
