Injector dead time calculator
This is my take on a dead time calculator. Fill in the blue fields, and the spreadsheet will calculate flow rate and dead time for you. No other manual steps required.
If you have a guesstimate of the injector parameters the spreadsheet will calculate the number of squirts required to fill the measuring cylinder 90% full for each pulse width - saves on overshooting the maximum measurable volume and having to run tests multiple times while still ensuring a fill ratio that provides good accuracy.
Enjoy!
Enjoy!
Joachim
1974 Jensen-Healey
2014 Ford Fiesta EcoBoost
1974 Jensen-Healey
Re: Injector dead time calculator
Could you add some scree shots of how you set this up in tuner studio. I bet this could be used by people willing to build a test flow bench.
Way cool
Andy
Way cool
Andy
I could post some screen shots, but not tonight...
Everything you need is in the "CAN bus/Testmodes"=>"Output test mode" dialog.
Set:
"Fuel pump" to "On"
"Test mode" to "Injectors"
"Injector testing mode" to "Single"
"Injector channel to test" to the channel the injector under test is connected to
and "Output interval", "Pulsewidth" and "Total number of injections" to the values indicated in the spreadsheet for each test.
The procedure is shown in http://www.youtube.com/watch?v=lJgi8l-2XG4
Set:
"Fuel pump" to "On"
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
Where did the spread sheet go?
Things like that spreadsheet need to be hosted somewhere off the forum and linked to. The attachments get pruned after a while to make space for more recent ones due to the limited amount of storage space available.
Hopefully the OP will see that and post a link.
I have it. Drop me a pm with your email and I will sent it to you.
Hi,Yves wrote:I have it. Drop me a pm with your email and I will sent it to you.
I am a new member and cannot PM you.
Could you please upload the calculator file on Google Drive or any other hosting
MS3Pro PNP, Mazdaspeed Miata 2004
Hi could you send me the link also? Or send the link on my email. sand.stian2@gmail.comYves wrote:I have it. Drop me a pm with your email and I will sent it to you.
Thanx
Online spreadsheet for Siemens Deka/Ford and possibly others here.
https://docs.google.com/spreadsheets/d/ ... sp=sharing
Link to the spreed spreed sheet I use to calculate dead time.
