Tooth Logger Help
Tooth Logger Help
I am using a 36 - 1 trigger wheel on an air-cooled VW engine with a Ford F150 VR sensor. Like this:
http://www.maxwelton2k.net/squareback68 ... index.html
Problem is that while the tach signal seems fine while cranking (ignition and injectors disabled), I'm getting weird behavior when I actually start the engine. I have attached two logs, one while cranking and one running (sort of).
I'm new to this. What does that look like?
I'm running MSExtra Rel 2.1.0p
Max
Max
Re: Tooth Logger Help
Sorry ... here is my CurrentTune
Max
Max
Man.... That is some old firmware!I'm running MSExtra Rel 2.1.0p
You might want to update that.......
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Depending on the exact version that's about four years old. Lots has changed since then.kjones6039 wrote:Man.... That is some old firmware!I'm running MSExtra Rel 2.1.0p
OK, I'll update the firmware tonight and see if it changes anything.
Max
Max
Firmware now 3.2.5. No change.
So here's what I'm seeing. The tooth-log looks normal when just cranking. Let the engine start and I start loosing the signal.
Any ideas?
Max
Any ideas?
Max
You're seeing noise pulses - the little "dips" in the screen shot posted are noise, pulses that shouldn't be there.
OK, that makes sense.
I'm using a pre-made harness from DIYAutotune from several years ago and I don't think that wire is shielded.
Thanks!
Max
Thanks!
Max
We've used shielded wire for the crank sensor input in our harnesses for the past 8 years or so - it's possible there may have been an unshielded version sold here before I worked here.
It has worked fine using the stock coil (-) as the trigger for three years.
But I also have a very recent DIY harness that includes a bit more of the pinout that I was planning to use on an MS3 project. I may retask it to this car as it supports the spare-4 pin which I need for the 2nd coil driver output anyway.
Max
Max
Progress. First, I misspoke about the IGN wire not being shielded. It is shielded, was just buried under some wrapping I had used when I set it up initially. I re-routed it for better separation with the HT leads and installed the 10k resister. The miss went away. But I was getting drops (visible in the trigger logger) at idle.
So I went back and read http://www.msextra.com/doc/general/toot ... mples.html some more. There is an example of what the tooth logger looks like when the VR is wired backwards. Looked a lot like mine (when cranking).
So I reversed the VR wires and my tooth-log looked normal ... and the sync-loss at idle cleaned up.
It's magic, I say. Magic!
So now I'll set about pulling out the stock coil and installing my IGN4.
This place is great!
Max
Max
I was going to suggest that the other day lol, but when I had my vr wired backwards it looked almost identical to the diy example pick and didn't want to possibly send you on a goose chase.
Wasted Spark Help (was: Tooth Logger Help)
So now that I've swapped out the single coil for an IGN4 coil pack, I'm having a new problem.
The engine ran fine for a few minutes, enough for me to get ~5 miles from home, then TS gave me this weird message:
I was able to restart by cycling the ecu, but it would die again a < 30 seconds later. I repeated this long enough to get back home.
So, the message indicates "serial noise", but the timing seems more like something that is temperature related.
This was working fine when I was driving a single coil so it's something to do with introducing the ING4 in wasted-spark mode.
PS: The engine would continue to run for several seconds after that dialog came up. The attached log shows some of the trip home. The "Time" trace shows the intervals to the stoppage.
TIA
Max
TIA
Max
there is something up with your voltage in to the ecu its reporting up to 28v guess that will cause a reset have a look at the alternator maybe?
Not to mention, when Batt V goes to -1740.8!grom_e30 wrote:there is something up with your voltage in to the ecu its reporting up to 28v guess that will cause a reset have a look at the alternator maybe?
I would be looking at grounds (and wiring in general) along with the alternator.
Wow. Good eye!
The voltage regulator is right close by where I mounted the MS and the FI harness passes close by as well. Entirely possible I dislodged something. Back out to check.
Max
Max
Those reported values in the datalog are serial corruption, it is impossible for them to be real.
OK, replaced the voltage regulator. Actual voltage now does not exceed 14.5 volts. The TS dashboard gauge and the datalog read almost a full volt higher than what my volt-meter says.
It starts right up and runs well, but still only talks to TS for a short time before the previously posted dialog comes up. Now that I know the actual bus voltage isn't dangerously high I think I'll drive it to work tomorrow and see if will halt or just stop talking to TS on my laptop.
Max
Max
The plot thickens.
The old windows laptop I've been using in-car has been having random problems with its USB interfaces and also hanging while shutting down. So I pulled out an even older PC running Linux and TunerStudio MS v1.006 (!) Using the old Linux machine I was unable to get TS to freeze or MS to stop working. And BatV reported through TS was in agreement with measured voltage at the generator.
So my new theory is that my windows laptop has some sort of fault that is capable of taking down the ECU through the serial i/f.
I'm going to drive around like this for a while and see what happens.
Max
Max
Can someone point me to the tooth log examples? The old link doesn't work.Max Welton wrote:So I went back and read http://www.msextra.com/doc/general/toot ... mples.html some more. There is an example of what the tooth logger looks like when the VR is wired backwards.
Max
