The sticky thread with 3.3.1 in the subject: http://www.msextra.com/forums/viewtopic ... 01&t=52147Philip Lochner wrote:Where do I get 3.3.1? Keen to try it. Search does not search on 3.3.1...
I looked at it James....jsmcortina wrote: Have you tried the current release 3.3.1 ?
I thought I read that Barometric timing correction was going to be deleted, but perhaps this does not apply to the regular Extra code since its never been there?jsmcortina wrote:What features do you think were being deleted?
Is it your challenge to make the most posts to this forums about a single issue in one day?Philip Lochner wrote:The possibility of Barometric fuelling and timing correction being dropped scares me in a big way
I panicked. My sincere apology. Won't mention this ever again.jsmcortina wrote:Is it your challenge to make the most posts to this forums about a single issue in one day?Philip Lochner wrote:The possibility of Barometric fuelling and timing correction being dropped scares me in a big way
Also, how can baro timing be "dropped" when it hasn't been added?
Phil, was this car dyno tuned for ignition timing? If so, what altitude?Philip Lochner wrote:Further to the above posting, I have posted this (http://www.msextra.com/forums/viewtopic ... 34&t=52326) hoping to present a case as to why BOTH fuelling AND TIMING barometric correction is needed and should be offered by all FW versions of MS.Philip Lochner wrote:A timing advance retard table vs Baro - similar to MAT based advance/retard.
I never could understand why, when travelling to the coast (dropping from 1500m / 4500ft) to sea level brought with it the onset of pinging, even at partial throttle despite stating out with timing map with 0 pinging. I thought that having an absolute pressure based timing map would eliminate altitude related pinging and that I would only have to tune the high kpa bins once I get to sea level. It is important to understand that I tuned the engine at 1500m where I live and can not tune bins higher than 85kpa because that is WOT at this altitude.
When you have 60kpa MAP at higher altitudes, is it not the same as having 60kpa MAP at sea level? After doing the sums as reported here (http://www.msextra.com/viewtopic.php?f= ... 20#p203139 - and assuming they are indeed correct) I now understand that 60kpa MAP at higher altitudes, may not be the same as having 60kpa at sea level by virtue of different cooling drops over the TB causing different air densities, which could also be contributing to different AFRs and ultimately different timing requirements. Combine this with the effect of changing back pressure at the exhaust....
Fortunately I realised that changing my trigger offset would move the entire table up or down and this is how I sorted the problem on the way to the coast - PC on the wife's lap
There is talk of timing correction in particular being dropped and I'm having a hard time explaining to the devs (and convincing them) why this feature is definitely needed. I was so convinced (and still am) that I need this feature that I PAID a code writer to add this feature for me!! I was having detonation issues on my high compression Rover V8 even when dropping from 1500meters to 1000m.
Peter, it was dyno tuned (on a load dyno) for timing at 1500m.Peter Florance wrote:Phil, was this car dyno tuned for ignition timing? If so, what altitude?
Did the motor detonate at part load or full load?
Philip Lochner wrote:Peter, it was dyno tuned (on a load dyno) for timing at 1500m.Peter Florance wrote:Phil, was this car dyno tuned for ignition timing? If so, what altitude?
This is the interesting thing, it detonated at partial load around 60-70kpa (around 2600rpm) after having dropped from 1500m to ONLY 1000m!!! Stepping on the gas pushed the load up to beyond 85kpa where we entered conservative guestimates which turned out to be conservative enough to avoid detonation. Once I got to sea level I did tune those bins by "seat of pants" method (advance till ping, retard 4 degs.)
Now that I have Baro based timing correction (compliments of gslender) I no longer have this issue and no longer need to fiddle with MS settings as I travel along varying altitudes.
This issue is a particular problem on high compression normally aspirated engines which are subjected to varying altitudes - and ever more so if fuel octane is lowish. Someone who's engine was tuned at sea level may not ever know that his engine may have untapped reserves (with advanced timing) when going to higher elevations but most likely will ascribe diminished performance to altitude only (less dense air) - thus won't even understand / see the need for this feature.
I'm not seeing how the method you describe would give a different result from the existing MAP/RPM spark table ? Or rather, you didn't discuss how your "engine load" is determined.Sellig78 wrote:But even at WOT the engine load is not always 100%. If you look at you're look at your VE table you will see a maximun value for a fix MAP/RPM (if you have the AFR incorporated) witch correspond to the 100% engine load.
That's why a engine load/RPM ignition table is better, the spark advance depends only of the quantity of air inside the cylinder. So if you're travelling at different altitude the engine load will change and the spark advance too.
All OEM use this in their EMS for the spark table.
Cheers
Huh? Is this correct? If so, how is the pressure measured on both sides of the Throttle Position Sensor? I thought I understood Manifold Absolute Pressure, but apparently I don't!The MAP sensor doesn't measure the engine load. It measure the difference of pressure before and after the TPS.
