He is mistaking the difference between an absolute and differential(gauge) pressure sensor. A differential has a vent to atmosphere which would give the results described (ie. pre/post TPS), The MPXA4250 MAP sensor most of us are using has a sealed internal reference pressure which allows a reading of absolute pressure. We add in the baro sensor to measure the "vented" pressure then calculate the differential pressure (%baro).kjones6039 wrote:Huh? Is this correct? If so, how is the pressure measured on both sides of the Throttle Position Sensor? I thought I understood Manifold Absolute Pressure, but apparently I don't!The MAP sensor doesn't measure the engine load. It measure the difference of pressure before and after the TPS.
Did I just misunderstand this post? Maybe I shouldn't have sold that QuadraJet!
Hope your truly confused now!
Later Ryan
