Is there a video on the functions of AE, i.e. what does what?
I can"t seem to wrap my head around exactly how to set it up correctly.
I kind of understand how it works but a video would be awesome.
I am not looking for an easy out, I have read until my head hurts but can't seem to get it spot on.
If not would some one with this knowledge be willing to make one.
I know I am not the only one who would benefit from it.
Thanks, David
Accel Enrichment tuning
Re: Accel Enrichment tuning
Oh well, it was worth a try.
Which AE do you refer to? TPA/MAP based or Enhances Acceleration enrichment?
If you have troubld understanding how it's working, i would suggest to start with TPS/MAP based, and propably not a blend, but 100% TPS or 100% MAP whatever fit's your setup more.
I for example used 100% TPS AE for a long time in my Turbo Engine. You will not get Lambda 100% exact, but this is also not necessary but more a nice to have.
Tuning is actualy very simple and can be done in 1-2h mostly...
If you have any detailed questions, i can try to take a lookup when i'am at home.
Honda CRX B16A1 Turbo | MS3 running | pre1.5.1 beta7 Firmware | 24/1 Dual Wheel | COP ignition | 725cc ID injectors
