Hello, I have a question concerning the distance from the exhaust valve to the O2 sensor. It seems logical that closer is better, but is that true? I mounted mine when I still ran a carb, and placed it near the back of the car. It is approximately 110"(2.8M) from the exhaust valve. Is that too far back? I understand that there will be a slight delay required for things like EGO correction, and that logs will show a lag in response on the O2.
Thanks,
JP
o2 sensor position
o2 sensor position
MS2 on Ford 351C, custom internal crank trigger, FAST EZ-EFI TBI, LS truck coils in wasted spark
Re: o2 sensor position
The recommended distance for mine was 40".
Cheers Luke
Cheers Luke
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
MS2 V3
Tech Edge O2
London UK.
That page is the one I used to set mine up as it is a tech edge 2J1.
Cheers Luke
Cheers Luke
