Just a quick look, but I would suggest adding fuel, seeing you are running ITBs, trying doubling your accel % through the whole range and see if the gets better or worst.
later wd
rich misfire? lean afr reading
Re: rich misfire? lean afr reading
Hey Wrench,
I have been removing fuel and the engine seems to be getting better. I just wanted some other opinions on that section of the fuel table. the more fuel I have removed, the better the acceleration has been and the smaller stumble. It used to be if I stabbed the throttle below 1500 rpm the engine would occasionally stall and I would have to restart. now the stumble is a small cough and hesitation then it takes off.. I am just noting the fuel pulse width during the lean spike and it is the most fuel the engine receives in the entire log. which is why I am thinking misfire. if you see the third log the engine runs great, its accelerating pretty fast and has no misfire/lean spot. (also not hitting the accel enrichment low limit)
Go with what works I always say!!
THE best thing I did for accel is turn on EAE, I haven't really got it completely worked out yet but it help a lot on the right off idle stuff with my ITBs with the default settings
later wd
later wd
thanks WD. I think I will try to remove some more fuel tomorrow, but I think I will make a fairly large change in the section of the ve table at 90 kpa and above in the 1100 and 1400 bins... going to try dropping about 8 full points from those bins. then datalog my test drive. I would love to see a change in the afr reading and lose that misfire.
this is the msq I am going to install tomorrow or Saturday.
I have been adding more resolution to the ve table bins and now I am going to table switching to increase the load bins... I think this will make my life simpler.... I have found several places where the low rpm high kpa bins had way to much fuel.. this new tune should make my tuning easier because of the bin resolution improvements.
