First : I tried posting my log, but the system here doesn't allow for more than 1MB in file.
Did a run and experienced some backfiring and some minor popping in the exhaust. During an acceleration, it was more severe. Had AE on when I was doing the run.
I can see spikes in the logs when the tps is going up and then going over to a flat line. So it's right were the tps is going flat and it seems to be lean right before on the ramp up. I didn't notice anything other abnormal. The pointer seems to jump up in the same rpm range quite a bit according to map.
Is this something rather related to my tables not being dialed in or the AE ?
backfires an popping in the exhaust question
Re: backfires an popping in the exhaust question
Try shortening the log with MLV, or putting it in a ZIP file.
MLV ?Matt Cramer wrote:Try shortening the log with MLV, or putting it in a ZIP file.
MegaLogViewerYves wrote:MLV ?Matt Cramer wrote:Try shortening the log with MLV, or putting it in a ZIP file.
1990 Nissan 240sx / SOHC KA-T / DIYPNP
Excuse me the dumb question, but how do you shorten it in the viewer ?
PS : I have been looking at the logs, seems like the PW doesn't really move a lot during an accel. AFR is pretty lean then >17. Also during decel she's pretty rich it seems, < 13.
in mlv, search pull down,log editing , delete before or after cursor- resaveYves wrote:Excuse me the dumb question, but how do you shorten it in the viewer ?
A shorter datalog of a run around the block, mainly targetting 1800 and 2300 rpm ranges. AE was put at 1000 %/s to not have it engage.
I noticed that the ign. timing seems to wander. This is a GM HEI with 8 pin module (TPI era Camaro type distributor) but an MSD version of that. Am I looking at a problem here ?
Ignition control is set to speed density only.
Will put this in another thread specifically about this wandering as well.
