streetrover wrote:Ok...so theoretically grom_e30 because the VE table is a factor in the PW calculations lowering every cell by say -- 10 -- would cause less fuel to squirt into the engine. And I could see the resultant change on my pulsewidth gauge. Even though I CAN do this, however, SHOULD I do this?
That is the basis of tuning yes. Adjust the VE table.
Those oxygen sensors are narrowband. While you can wire them straight in, they won't tell you a great deal compared to a working wideband.
What country are you in?
I've had success with TechEdge wideband controllers.
Thanks for the info on the O2 sensors. I'm in Los Angeles, California. Yeah, I was told the wideband was better. Just not looking forward to shelling out another $200 for controller/sensor kit. TechEdge eh.
Ya know, Innovate is based in Irvine, CA. Maybe I drive 60 mins and throw a fit in their store. Wonder if they'd swap it for a "good one."
Bob
if the wideband is not very old it may be worth and email or phone call to see if they can offer any solution for it, i have seen the the innovate products have gotten a bit of a bashing questioning reliability and functionality but i have been running a lc1 in my car for the last 2 years driven daily and a lc2 for 6 months in my bike and although i have not tried another brand to compare to.... they are working for me without issues.
Hmmm...did a little more research and discovered that the sensor Innovate uses is a Bosch 17014 that fits a 99-05 VW Jetta 1.8L-L4. It's about $60 new. I think my earlier decision to try to "program" the controller/sensor is a good one. Gonna do that now...
have you checked your timeing with a light yet? it might be retarded.
i wouldnt touch the ve table yet, your idle and part throttle should be ballparked im willing to bet the higher loads a rich yet but don't want to chance it without knowing how much.
I "programmed" the Innovate controller. I generally used the defaults except for one window. I've displayed it below.
I made a change to the voltage values for warmup and error codes. For the warmup instead of 0.00 I entered 1.00. And more significantly, for the error code value I entered 2.50. My thought was that even when the controller goes into E8 mode, it'll still be sending a voltage to the ECU that its reading halfway between 7.35 and 22.4 AFR (basically 15.0). Sure enough, just minutes into my drive the Innovate gauge went E8 but the TunerStudio gauge didn't plummet to 7:1. Instead it fluctuated between 12:1 and 19:1. Now, all this may be a pack of lies as ashford pointed out. I guess the next step is to find a way to calculate mileage (odometer doesn't work). Car sure does run better thanks to ashfords tunes!
Here are the logs I made after the changes.
the problem with that is you are still feeding the ecu information that is next to useless how are you ever going to get the real afr the engine is producing close to where you want it to be if you still don't get reliable feedback from the wideband it still leaves you in a situation where tuning is going to be very difficult.
