Typical EGT temps
JAM
Typical EGT temps
Post by JAM »
A general question looking for some real world feedback- what EGT temps do you see at idle and WOT? What engine and application do you have? I know this can vary depending on a million variables but lets hear it!
grom_e30
Re: Typical EGT temps
Post by grom_e30 »
I see about 400c at idle, and about 760-780c cruising at 70mph top gear and is see maybe up to 800c under full throttle from 70mph cruise speed. on a bmw m20b25 n/a inline 6 2valve per cylinder engine.
ashford
Post by ashford »
this varies a bit for me, i have the iox with 8 egt. being cheap i bought 8 cheap probes. they vary about 200* f for me switching the physical probes around temps follows the probe not the port it was in.
i have a turbocharged sbf making around 750-800hp running e85 typical temps for me are 1500-1700*F, i did however have a wasegate failure once and run up to 20 lbs boost and not enought injector, i saw a brief mid 14 afr and egt of 1950* :shock: .
turbo conversion
Post by turbo conversion »
ashford wrote:this varies a bit for me, i have the iox with 8 egt. being cheap i bought 8 cheap probes. they vary about 200* f for me switching the physical probes around temps follows the probe not the port it was in.
Do you not have over boost protection?
ashford
Post by ashford »
at that time no, i had afr and egt safety, egt safety added more fuel and maxed out injectors/pump then afr safety shut the engine down
