I haven't posted much, but have been lurking around for about 18 months. I am relatively new, and have not begun to get into the more advanced tuning.
I have an MS2 3.0 with the 3.3.2 firmware. I have a consistent issue with AFR and load oscillation off idle, or more accurately, slightly on throttle. I have noticed the oscillation most often after a shift to 2nd and to 3rd under much less than spirited driving conditions. The attached data log shows the same oscillation as the motor loaded up as I exited out of a cloverleaf.
Could one/some of you guys take a look at my data log and tune and see if you can find what I am missing.
Thanks,
Jeff
AFR Oscillation off idle
Re: AFR Oscillation off idle
Looks like an O2 correction overshoot. Try setting the EGO controller authority to zero and tuning the fuel table to better hit your target AFRs in that area, then you can turn it back on. The more accurate the VE table, the less O2 correction driven oscillation you're likely to have.
Thanks, I'll give it a try
Thanks for the tips.
I turned off EGO correction, tuned on a warm day, then set EGO authority to 12%. No more oscillation.
