16vboost wrote:Sure, set lags to 100 and do a data log.
set all the lags to 100 except the MAF because I don't use it.
Thank you!
This question really needs to be answered....16vboost wrote:It really depends on the symptoms. There's nothing necessarily wrong with the signal. How's the car running?
-Alex
Thanks Alex I tried tuning my accel a little tonight by turning up the threshold to 80 so about what you said I also add about 2 ms to the whole scale it didn't like it, it buck like a bronco! its weird no matter what I do unless I set it high on the scale I get a lean spike id say a mil sec then it goes rich...on the gas law scale I assume you'd raise the scale throughout? so ego isn't working huh that's weird I'm pretty sure its enabled any ideas why it wouldn't be working? when I've turn up p it doesn't like it above 5016vboost wrote:For time-based AE, I'd set TPS dot as low as possible. Too low and you'll get unwanted AE pulses. So as long as AE only kicks in when you actually press the throttle and need it, you're not too low. In nathanhardy's case I'd raise it to about 50 cause I see multiple AE pulses being added with very little throttle movement causing the AFR to go too rich. Another trick that I've found to avoiding multiple AE events during a single throttle press is to set the accel taper time longer like .7s. Ultimately, you have to experiment with the AE curve and all the other AE parameters to get it to work as good as you can. And keep in mind that while the logs are essential to tuning, the last word should be seat-of-the pants feel. Otherwise, you may be chasing your tail trying to get a perfect AFR that stays within .1 of the target during throttle stabs.
I was talking about the ideal gas MAT table. I'd leave the MAT CLT table as is for now and only use that a little bit when dealing with heat-soaked hot starts. I did see that your EGO correction is always at 100 (meaning that it's not correcting at all). Again, I would get that working. Probably with PID.
-Alex
