I have heard conflicting things in regards to how to tune closed loop boost with the new sensitivity slider.
Is it to be used separate of the PID settings or in conjunction with? One version of the process involved setting the sensitivity first, then adjusting the PID values. If that is the case, what are the initial PID values?
If not using sensitivity slider, what is the sensitivity you should set it to in order to place it on "standard" sensitivity?
Thanks!
Close loop boost - sensitivity slider usage
Re: Close loop boost - sensitivity slider usage
I am not sure on the boost, but the slider was discussed per tuning the idle control here
http://www.msextra.com/forums/viewtopic ... 03#p406520
MS2 or MS3?
The slider is covered in the Megasquirt-3 Setting Up manual. http://www.msextra.com/doc/pdf/Megasqui ... Up-1.3.pdf
Thanks. I'll look through it later.
How long has this document existed (in any released form)?
A week.Chiburbian wrote:Thanks. I'll look through it later.
Great, then I don't feel so bad about not having read it LOL.
