Hello,
I wonder why the default IAT correction curve is not a straight line.
Since air density is proportional to temperature it should be imho.
Can anyone explain that to me ?
IAT Correction
Re: IAT Correction
I ended up making mine almost a strait line. Anything off of it was a massive deviation in fueling for me.
I know it's an area that could be made easier for some that's for sure/
1968 Dodge Charger, 446ci 513HP/542ftlbs,Full sequential fuel/Spark using MS3X. Jeep CPS, Ford Crank sensor, 36-1 wheel, Coil near plug with D-585 ls2 coil packs. Edelbrock pro-flo intake, 600cc injectors, GM MAP, TPS, IACV, CTS, MAT. 92mm Throttle Body.
Re: IAT Correction
The fact that a fairly straight line corrects an engine suffering from heat soak (as mine does also) actually proves a straight line is not correct for an ideal situation where IAT is always reading the true temperature of the air being ingested.
Cheers Luke
Cheers Luke
