Hi All,
In the manual, when using Alpha N on V3 code, the fueling algorithm is shown as :-
PW = Req_Fuel * tps * VE(tps,rpm)
Is the TPS factor the raw throttle position value or is it the calculated output from the TPS-MAP table? I can see that the VE(tps,rpm) uses the calculated tps value.
DerekJ
Alpha N fueling algorithm
Re: Alpha N fueling algorithm
as far as im aware it uses the calculated tps 0-100%
OK Understood.
