So I started to tune an engine again that I had pretty much tuned before, but I could not get the previously functioning tune loaded on the new firmware (v1.3.2 for MS3) so I've been starting from scratch.
I'm having an issue with the engine randomly shutting off. It seems my timing is going to -30 degrees advanced, so I'm a little confused. I have a wasted spark Ford V6 wih sequential fuel injection.
If there's anything else you see let me know.
Engine Randomly Shutting Down
MS3Pro Ultimate
1994 Thunderbird SC
Fully Sequential, SVO Odd Fire V6
IGN-1A Coils - Brisk resistor plugs
12 magnet IW wheel (troubleshooting Holley 554-124)
Ford factory half-moon hall effect cam sensor
Using Dual Wheel non-missing tooth crank wheel strategy
Twin Turbo / TH400
1994 Thunderbird SC
Twin Turbo / TH400
Re: Engine Randomly Shutting Down
anti lag is turning on hence the 30 deg timing thing
